Arcade Collecting > Miscellaneous Arcade Talk
PGA Tour Golf by Global VR & EA Sports Owners Thread
<< < (530/531) > >>
Captainspaulding:
--- Quote from: ajmorris74 on August 16, 2022, 12:35:56 pm ---
--- Quote from: Captainspaulding on August 13, 2022, 07:49:04 pm ---
--- Quote from: drummer_god on August 13, 2022, 07:42:31 pm ---Run the installation dics again;
Recovery disc then game discs 1-3
If your goal is to get online, then do not run the all access pass patch disc.
Are you still planning on upgrading to a better computer? If so, you should probably do that before going online too.
I upgraded to 1.5GB of RAM and used a solid state drive and it's running really smooth and boots so fast.
I'll go back through and leave all access pass off.
Thank you!
What computer model did you end up using?
Andy
I ended up leaving the beige case computer that was in there.  1.7GHZ - I upped it to 1.5GB RAM and took the ticking time bomb mechanical drive out and swapped to solid state media.
ajmorris74:
Hey All,
I have picked up a couple of Golden Tee Fore Cabs and will do the conversion as Tom did in his videos.  Where can I get the side art, top Marquee, and the Center info?
I will post pics later today of the cabs before the conversion.
Andy
drummer_god:
I responded to you via FB messenger
ajmorris74:
Cabs before the conversion.
ajmorris74:
Increase resolution in the game?
I have noticed in a few Youtubers that their screen looks larger than 800x600 and the corner info is smaller.  I have one cabinet hooked up to a 27" screen that I would like to try this on. How did they do this?  I will double-check the FB group, but so far I have not found the info.  I did see some talk in this forum but not a 'How to".
Andy
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
