Author Topic: Shortest Barrel Pushbuttons  (Read 1519 times)
rsigamer
  • Last login:March 11, 2013, 04:23:12 pm
« on: November 28, 2012, 01:25:33 pm »
Hello,
I'm looking for some arcade pushbuttons that will take a standard Cherry/whatever microswitch with the shortest possible barrel.
Paradisearcade have some that are 52.5mm, measured from the bottom of the bezel to the bottom of the leg.
I really could use some that are shorter still.
Any suggestions?
Thanks.
  • Last login:May 05, 2024, 08:59:50 am
Re: Shortest Barrel Pushbuttons
« Reply #1 on: November 28, 2012, 01:40:02 pm »
If you don't find what you're looking for and don't need many, I once chopped a section out of the center and glued it back together.
Just cut the housing toward the top so you still have the threads where you need them and cut the same amount from the plunger in the middle.
If they feel too stiff, cut the spring.  :P
  • Online Online
  • Last login:Today at 06:14:00 pm
« Reply #2 on: November 28, 2012, 02:11:16 pm »
Is there a reason you don't want to consider using Ultimarc's Goldleaf buttons?
They are only 1.312" from the bottom of the bezel to the bottom of the button.
DrChek
  • Last login:March 20, 2024, 10:41:01 pm
« Reply #3 on: November 28, 2012, 02:19:06 pm »
These are great. Highly recommend.
jpS14
  • Last login:October 04, 2022, 04:34:26 pm
« Reply #4 on: November 28, 2012, 02:36:30 pm »
there's always sanwa pushbuttons
two40
  • Last login:December 28, 2020, 01:33:38 am
  • What does this button do?
« Reply #5 on: November 28, 2012, 05:35:12 pm »
Seimitsu buttons are also pretty small. Much like the Sanwa ones.
rCadeGaming
  • Last login:December 20, 2023, 09:16:09 pm
  • Just call me Rob!
« Reply #6 on: November 28, 2012, 08:16:18 pm »
+1 on Japanese parts (including joysticks, especially Sanwa).  More compact, and IMHO much better all around.
rsigamer
« Reply #7 on: November 30, 2012, 05:44:27 am »
That's a brilliant idea! Never thought of that.
What kind of glue did you use? Epoxy?
rsigamer
« Reply #8 on: November 30, 2012, 06:22:40 am »
Because they won't take the microswitches I have here?
« Reply #9 on: November 30, 2012, 08:50:12 am »
I used superglue, but epoxy would probably be better.
It was on the start button of my newer driving cab dash, so it doesn't get as much use as a normal button.
I would think it would hold up fine as long as the nut isn't overtightened and kids aren't prying at it.
  • Online Online
« Reply #10 on: December 01, 2012, 07:50:36 am »
Is there a reason you must use those particular switches?
Do you have something wired through the NC contacts?
Which is the better deal -- reusing your current switches + the time and effort (and possible errors) modifying the buttons or buying the goldleafs?
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #11 on: December 01, 2012, 10:02:35 pm »
With switches like these or the Sanwa and Seimitsu ones, you won't need the micro switches. They are built in and silent
