Author Topic: Do the TurboTwist spinners fit in regular button hole?  (Read 831 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: November 25, 2012, 12:46:26 am »
Do the turbo twist spinners fit in the same hole as the regular buttons do?
  • Online Online
  • Last login:Today at 06:14:00 pm
Re: Do the TurboTwist spinners fit in regular button hole?
« Reply #1 on: November 25, 2012, 01:08:01 am »
Regular TT2 - Yes.  Randy designed them to do just that.  You can tighten the nut using a standard button wrench. (right)
TT2 High/Low - No.  Different mounting method.
« Last Edit: November 25, 2012, 02:09:14 am by PL1 »
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #2 on: November 25, 2012, 01:20:32 am »
Just curious.  What is the mounting method for the push/pull spinner?  I checked Randy's site and didn't see any mention of this.
D
equlizer
« Reply #3 on: November 25, 2012, 02:02:46 am »
how about the ultimarc spintrak? same as TT2 regular?  which one is better?
  • Online Online
« Reply #4 on: November 25, 2012, 02:52:07 am »
They are fairly similar.  Small difference in resolution IIRC, different knob choices.
Looks like when the flywheel is installed on the SpinTrak, it prevents you using a button wrench.
"which one is better?" - You trying to spark another Randy vs. Andy thread here?   :jerry   :laugh2:
To avoid throwing gas on that fire, I'll just say that after long and careful evaluation, I chose the TT2 spinner, a U-Trak trackball and a Mini-Pac Opti encoder w. wiring harness. YMMV.
Here's the product announcement thread.
Here's an offer to e-mail the template and a mention of how to undermount the TT2HL to a metal panel.
Other than it being a relatively low-demand item, I'm not sure why he doesn't have the template PDF link or a pic on the product page.
EDIT: Le Chuck posted a great pic below showing the cutout required.
« Last Edit: November 25, 2012, 07:00:22 pm by PL1 »
  • Last login:April 30, 2024, 07:38:23 am
« Reply #5 on: November 25, 2012, 11:56:52 am »
D
It comes with a template and you make a crazy hole that looks like this:
It's not as bad as it looks but it does take a bit of finesse.
