Main > Everything Else
Recommendations for DDR3 RAM?
<< < (3/3)
Grasshopper:
--- Quote from: edekoning on November 25, 2012, 02:16:53 pm ---Either 1600 or 1866 would be fine. The only thing you got to look out for is if the memory will fit under the chosen CPU cooler. What I mean by this is, is that if you are buying a big CPU cooler it may sit over the memory slots. If that's the case than the memory might not fit if it has large cooling fans, like the one you selected. Instead you should opt for 'low-profile' memory modules.
I did think of that but I couldn't find any low profile modules with the same spec on Corsair's site. I guess I could go with another brand.
edekoning:
You could try the corsair vengeance modules: www.corsair.com/us/vengeance-low-profile-16gb-dual-channel-ddr3-memory-kit-cml16gx3m2a1600c10.html
Navigation
[0] Message Index
[*] Previous page
Go to full version
