Main > Project Announcements
Hogie's manually rotating bartop
<< < (2/2)
Hogie1418:
--- Quote from: TopJimmyCooks on November 16, 2012, 08:42:42 am ---One thing to watch out for:  Vesa mounts on monitors are not always dead center vertically, so you need a display with centered mounting or an offset plate.
Thanks for the heads up on the vesa mounts. I had no clue that they were not centered on the back of my monitor. It looks like i will need an adapter plate to make up for how offset the monitor mounts are.
--- Quote from: BadMouth on November 16, 2012, 09:09:23 am ---
I created the outline of my monitor on foam project board, marked the outline of the screen and punched out VESA mounting holes where they are on the monitor.
Then I marked the center point of the screen and made another set of mounting holes centered with the screen and rotated 45 degrees so there would be clearance between the old mounting holes and new ones..
Those 8 holes are the pattern for your adapter plate.
Pics in reply #9 of my build thread: http://forum.arcadecontrols.com/index.php/topic,119308.msg1270530.html#msg1270530
Looking forward to seeing how this developes.
I've been wanting to make a budget bartop with manual rotation, but have way too many unfinished projects already.
So if I am understanding correctly, you created an outline for the 8 holes and used an adapter plate to help center the monitor with your rotation mount. Looks like the way to go  :)
Ive been wanting to build another cabinet for awhile now but a cheap bartop will hold me over until I get a bigger place.
--- Quote from: Lord Hiryu on November 16, 2012, 01:10:13 pm ---Sorry...it's in spanish....but you can take some nice ideas for your forthcoming bartop.
Luck with your project.;)
Finally my 3 semesters of spanish are paying off!!!! ok, I didnt follow perfectly but I will definitely find a webpage translator and follow your build!! Thanks for the link
--- Quote from: Le Chuck on November 16, 2012, 04:06:52 pm ---Check out DMWorking24/7's Alien Bartop it's a favorite of mine and was a huge inspiration for my Darkade build.  He does a really sweet out the front manual rotate that might be right up your alley.
The more resources the better I say. I had a hard time finding a build that did a manual rotation from the front so this will be great to look through.
Also, I must say, your darkade is what made me want to build a bartop of my own. My wife thanks you for that  ;)
PL1:
--- Quote from: Hogie1418 on November 16, 2012, 04:56:44 pm ---I will definitely find a webpage translator and follow your build!!
Here's one I've used for Russian, Romanian, Portuguese, and --occasionally-- Spanish.
(Bonus round: It also has a language autodetect function, just in case you're far from being a polyglot.)
http://translation2.paralink.com/translations.asp
Termin8tor:
Any progress on this, looks promising from the sketch.  :cheers:
Eldritch1969:
Rotating bartop ... ! That is really something I would try doing, too.
Good luck in your project !
darthpaul:
These rotating Bartops are getting some ideas flowing but I really need to finish my Automated cab first :embarassed:. Good luck with this, I'll be following your progress.
Navigation
[0] Message Index
[*] Previous page
Go to full version
