Main > Main Forum
Fresh XP pro install very slow
Pages: << < (3/3)
ark_ader:
I had the same problem when I installed it on a P2. I put more memory in it and it worked OK.
gman314:
I fixed it.  All I had to do was install the drivers off of the disc that came with the motherboard.  Everything works beautifully now.   :cheers:
cigardude:
--- Quote from: gman314 on November 12, 2012, 03:11:35 pm ---I fixed it.  All I had to do was install the drivers off of the disc that came with the motherboard.  Everything works beautifully now.   :cheers:
If there are newer drivers on the manufacturer's web site, I would grab those.
jammin0:
[/quote]
[/quote]
I second that, the drivers provided on the disc are sometimes out of date by the time it sits on the shelf and then you buy it.
gman314:
I will try that. Do you think that could make my emulators and frontend run better? As of now, I have no complaints with my XP.
Pages: << < (3/3)
Go to full version
