Author Topic: Which Act Labs gun should I buy???  (Read 1400 times)
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« on: October 20, 2003, 05:08:54 pm »
I'm interested in getting guns for my MAME arcade machine in order to play shooters.  My setup is as follows:
- Windows XP
- running a pretty new machine (2400+ AMD CPU)
- ArcadeVGA video card
- JPAC connector
- Real arcade 25" monitor - WG7000 series
Now, should I buy the PC one, and connect it between the ArcadeVGA and JPAC, or should I buy the TV one and somehow interface it to the S-Video out on the ArcadeVGA??  Since this is a real 15Khz arcade monitor, the highest resolution would be 640x480 interlaced.
Also, how well will 2 guns play on this setup? how will one wire something like this up?
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
Re:Which Act Labs gun should I buy???
« Reply #1 on: October 20, 2003, 05:56:03 pm »
you are using an arcade monitor, so you will need the TV guns (the PC guns only run on a CRT VGA monitor)
these guns support two players (by effectively sharing a four-button mouse between the two players)  BUT since this causes problems when you shoot at the same time, and MAME Analog+ supports multiple mice, you should set them both to "Player 1" and use the new version of Analog+ for MAME.
There is SO a spoon.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #2 on: October 20, 2003, 06:29:05 pm »
Not true.  The PC light guns work great on my ArcadeVGA/WG 25k7191 (standard res arcade monitor).
They didn't always work.  A week ago, I read Andy Warne's post here:
http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=10990;start=msg96068#msg96068
that explained why my lightguns didn't work.  I repaired the wiring on my VGA cable->Arcade Monitor hack, and it worked great.
I don't know if the TV lightguns can work, I didn't think they will if you're using a VGA cable hack.
« Reply #3 on: October 20, 2003, 06:51:33 pm »
You got it.  For arcade monitors you use the pc guns, not the tv guns.  The tv guns will not work as they use a svid dongle and will only operate at 60hz.
