Main > Everything Else
Halloween costume
<< < (2/6) > >>
lordnacho:
Heh sounds like a cool costume.
Trying to keep the costume small, so he can still run around.  If it's too bulky he'll just want out of it, so he can run around with his friends.  So I think his head and arms will be outside of the costume.  Actually mounted inside or out, he probably wouldn't be able to see and touch it at the same time.  I'll tinker with that corded remote/headphones, if I can find it.
ChadTower:
Running around is a key requirement.  If you make the hole in the box big enough, though, he can pull his arms in and out without any issues.  Put a yellow shirt/coat on him inside the box and nobody will notice if the hole is big.
lordnacho:
Good point.
I was trying to see how it would look on him, but he wouldn't keep still.  So I resorted to a photoshop mockup, found a silhouetteof a kid, much easier.
ChadTower:
Hahaha.  I had that problem exactly once with my older son.  He wouldn't be bothered to help me with his costume.  So I went to the store and got a cheerleader outfit and told him his choices were to help me make his costume or be a cheerleader.
He helped me make his costume without a complaint from then on.   ;D
lordnacho:
That's pretty good.
Would be scary if they were ok with that costume...not that there's anything wrong with it
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
