Author Topic: Any Shaft requests?  (Read 8516 times)
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
Any Shaft requests?
« on: October 05, 2012, 10:59:52 pm »
We are about to have another large batch of shafts run and I wanted to check and see if there is any consensus on something people would be looking for...
Here is what we have currently:
IL/HAPP x 2 varieties RGB, one version of 6mm threaded hollow shaft
Seimitsu/Zippyy 6mm threaded hollow shaft
Seimitsu/Zippyy long 6mm threaded hollow shaft
JLF 6mm threaded hollow shaft
JLF long 6mm threaded hollow shaft
JLF regular length RGB Shaft
Here is what we will be adding:
JLF long RGB
Seimitsu/Zippyy Long RGB
Seimitsu/Zippyy RGB
JLW RGB
JLW 6mm top for LED
We also may be doing a few more Magstik Plus Shafts
We don't have plans to do a long JLW, but that is a possibility.
Any other suggestions?
t3design
  • Last login:January 13, 2024, 07:19:01 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Re: Any Shaft requests?
« Reply #1 on: October 05, 2012, 11:25:45 pm »
I apologize in advance, but somebody has to....
Shaft request?
That's what she said.
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
yaksplat
    • Random Projects
« Reply #2 on: October 05, 2012, 11:51:34 pm »
What fits an Ultrastik 360?
http://yaksplat.wordpress.com
armi0024
« Reply #3 on: October 06, 2012, 12:07:51 am »
I had not intent of such a dirty title  :angel:
360's are tough to make led sticks because of the magnet placement, so please do not count on these shafts for that.  The base design is that of JLW though.
EightBySix
« Reply #4 on: October 06, 2012, 05:35:20 am »
Shaft request?
You're DAMN right.
(again, sorry in advance)
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #5 on: October 06, 2012, 09:21:15 am »
Two JLW shafts (or whatever is used in the ServoStiks.)
If you put the link up on your Paradise website, I'll pre-order mine today.
Is there an ETA?
Mental
  • Last login:May 18, 2013, 09:46:08 am
    • Complete cocktail arcade system
« Reply #6 on: October 06, 2012, 11:26:11 am »
I'd love to try out a couple JLWs.
Complete cocktail arcade system: arcadecabinets.ca
compute
  • Last login:February 26, 2018, 05:33:36 pm
« Reply #7 on: October 06, 2012, 11:43:41 am »
I'm just looking for a cat that won't cop out when there's danger all about.
xefned
  • Last login:June 07, 2021, 01:28:30 pm
  • Unearthing ancient threads is my special skill.
    • Matthew's projects
« Reply #8 on: October 06, 2012, 11:45:02 am »
Do you have any hollow shafts I can put a bat top on?
Crazy request I know, but I want to diy rig a top-fire-button on a bat handle.
Searching for Zwackery, not because it's rare, because it's fun.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #9 on: October 06, 2012, 12:07:34 pm »
An extended JLF one with an adapter that would accept a 1/4" shaft for rotary mods.  ;D
  • Last login:April 30, 2024, 07:38:23 am
« Reply #10 on: October 06, 2012, 01:52:35 pm »
 ;D :stupid
Oh hells yeah
MacGyver
    • Project Build
« Reply #11 on: October 06, 2012, 02:23:39 pm »
He's a bad mother...[shut your mouth].  >:D
Paul Olson
  • Last login:Today at 03:19:08 pm
    • Paul's Arcade
« Reply #12 on: October 07, 2012, 12:29:02 am »
I would really like to see repro tapper shafts. I want to add a couple to my MAME cab, but I don't want to rob a nice Tapper CP to get them.
armi0024
« Reply #13 on: October 07, 2012, 12:32:44 am »
Now that is in interesting idea, the thought of doing Tapper handles doesn't really sound as tempting as a small run of 3/8"-16 UNC threaded tops so you can add any tap you want to the top of your machine....
Paul Olson
    • Paul's Arcade
« Reply #14 on: October 07, 2012, 02:11:06 am »
I tried it with a full size Bud tap. It isn't as cool as it sounds. The small originals are a lot easier to play with. :)
Vebbo
    • Overaged Lucky Drivers
« Reply #15 on: October 07, 2012, 03:15:37 am »
Any chance for a happ perfect 360 hollow shafts?
Vebbo
Well Fed Games
  • Last login:March 06, 2022, 07:30:46 pm
  • Delicious!
« Reply #16 on: October 07, 2012, 06:19:38 am »
/OT, sorry
Any thoughts on when LS-56s will be back in stock?  I need two of the shafts... well the whole things actually. :afro:
/OT, sorry
MacGyver
    • Project Build
« Reply #17 on: October 09, 2012, 01:51:06 am »
Maybe you should change the title of this post to include the word "hollow".
armi0024
« Reply #18 on: October 09, 2012, 01:54:55 am »
they don't need to be hollow. I'm really looking for any suggestions people might hav
Unstupid
« Reply #19 on: October 09, 2012, 03:46:42 am »
Stubby JLW's for metal control panels to replace a pac man joystick.  :)
armi0024
« Reply #20 on: October 09, 2012, 03:55:03 am »
First off.... I think the JLW is the ideal Ms Pac replacement stick, I don't know why more people have not come to that realization
Second, you are the second person to ask for stubby JLW's, I will get a few dozen done for kicks, and just for better kicks...I'll do the threading so you can put the Wico replacement ball tops on them
Unstupid
« Reply #21 on: October 09, 2012, 04:01:57 am »
I ended up cutting the ones for my cocktail table down at the machine shop at work...  PITA though!  ended up taking off about 3/4" to get it to fit good under the glass.
Hey, just the other day when I was emptying out my backpack to take it to Disneyland I found a couple of nintendo buttons I made on my 3d printer...  do you still want them?  Email me your mailing address if you do.
Mental
« Reply #22 on: October 09, 2012, 09:51:00 am »
I would buy some of these in regular and hollow.
alfonzotan
  • Last login:November 28, 2023, 08:39:45 am
    • The Cab With No Name
« Reply #23 on: October 09, 2012, 01:38:20 pm »
Yeah, I'd be interested in a hollow version myself.
MacGyver
    • Project Build
« Reply #24 on: November 12, 2012, 05:16:21 am »
Is there an ETA on the hollow JLWs, can I place a pre-order, because I would hate to miss them?
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
« Reply #25 on: November 12, 2012, 08:28:10 am »
Could you do some replacement shafts for the Suzo 500 joysticks? They have a great feel and are 4/8/way switchable. However, the stock handles are very ugly.
GernBlanston
  • Last login:July 11, 2016, 05:53:06 am
« Reply #26 on: November 12, 2012, 08:42:41 am »
Ditto.  Watching/wanting/waiting.  Hollow JLW's, please.
RetroBorg
  • Last login:July 06, 2022, 09:22:13 am
« Reply #27 on: November 12, 2012, 08:50:25 am »
I'd be in for these too!
RetroBorg
« Reply #28 on: November 12, 2012, 08:52:31 am »
Double ditto for me.
armi0024
« Reply #29 on: November 14, 2012, 10:41:43 pm »
OK, first stock of shafts arrived.... JLW RGB shorties, JLW RGB regular and Magstik Ultra RGB's
Unstupid
« Reply #30 on: November 14, 2012, 10:42:53 pm »
I need 5 or 6... how much shorter than standard?  You have light springs for JLW as well?
« Reply #31 on: November 15, 2012, 12:08:28 am »
4" WICO Hallowed leaf shafts, with threaded top for pimping out my Robotron.  >:D
armi0024
« Reply #32 on: November 15, 2012, 12:22:16 am »
About 3/4" shorter...
I will need to double check with Wolfeel, we were going to release a hollow wico stick, I was also thinking about a replacement ms pac so you could put a pink or lit pink ball on there :)
paigeoliver
  • Awesome face!
« Reply #33 on: November 15, 2012, 12:33:57 am »
4" Wico shafts that take the assorted current asian balltops would probably be popular since the stock of NOS red 4" sticks has dried up.
armi0024
« Reply #34 on: November 15, 2012, 12:36:33 am »
Ahhh yes... but we have the replacements made to the original dimensions and color!
Magstik, JLW, JLW shortie
« Last Edit: November 15, 2012, 01:22:40 am by armi0024 »
« Reply #35 on: November 15, 2012, 02:26:48 am »
QFT
cammada
  • Last login:August 01, 2020, 10:59:21 pm
« Reply #36 on: November 15, 2012, 03:26:26 am »
I do really need those long hollow shaft that would fit with servo stick or j-stick......
I am starting to believe that hollow shaft are now getting popular and no wonder why Ultimarc or GGG or other arcade store is not selling........except Paradise arcade but Paradise's joystick shaft is confusing me because I don't know which shaft suit which joystick so I contact Paradise Arcade for enquiring and guess what, they never reply back.  :badmood:
armi0024
« Reply #37 on: November 15, 2012, 04:02:29 am »
I apologize, not sure what happened, I went back through every email with the word "hollow shaft" in it since August 20th and there were not unanswered emails about the shafts, but here's the scoop.
We have 15 different hollow shafts.  They are designed for the standard sticks carried in our store and offer a variety of RGB and single LED options.
I can not validate the shafts will work with other vendors custom sticks.  We are still in the process of creating our own 2/4/8 way switching sticks.  We will have a full light up selection for these sticks when they are finished.  If someone wants to measure the shafts on a custom sticks and send us the dims we can tell you if our shafts will fit.
PM me your email and I can do a search specifically for your email.
We have or will have the following (6mm threading is japanese standard, 10mm is for our custom ball tops and RGB ball tops, longs are all 3/4 inch longer than standard):
JLF 6mm threading
JLF Long 6mm threading
JLF 10mm
JLF Long 10mm
Seimitsu (also work for Zippyy) 6mm
Seimitsu Long (also work for Zippyy) 6mm
Seimitsu (also work for Zippyy) 10mm
Seimitsu Long(also work for Zippyy) 10mm
JLW 6mm
JLW 10mm
JLW 10mm shorty
Mag Stik 10mm
IL/Happ Skinny shaft 6mm
IL/Happ Skinny shaft 10mm
IL/Happ Standard shaft 10mm
We are also getting ready to release our custom LED joysticks with RGB tops prebuilt.
Mental
« Reply #38 on: November 15, 2012, 10:56:07 am »
Any plans for a regular JLW shorty (regular thread, not hollow)?
armi0024
« Reply #39 on: November 15, 2012, 12:14:34 pm »
No, but we plan on more 10mm threaded solid ball tops
