Author Topic: Flightstick Pro Conversion?  (Read 1538 times)
wcndave
  • Last login:June 10, 2021, 03:37:36 am
« on: October 04, 2012, 11:15:23 am »
I have an old flightstick pro, great in it's day, wing commander, star wars...
anyway it uses the old game port, and i would love to make it a USB pluggable controller for the odd games that need it.
Can I do this? can i get a gameport to usb converter? can i just take the wires, and and 2 will be ground / live and the rest will be "buttons" and map to up / down / left / right / fire etc...?
hope someone's done this before,  Thanks
Dave
  • Last login:May 05, 2024, 08:59:50 am
Re: Flightstick Pro Conversion?
« Reply #1 on: October 04, 2012, 11:22:28 am »
Just get a usb/gameport adapter.
I have this one and it works fine:
http://www.ebay.com/itm/USB-PC-to-15-pin-Gameport-Adapter-for-Flight-Joystick-C-/170495865357?pt=US_USB_Wi_Fi_Adapters_Dongles&hash=item27b258720d
There are some odd old controls that it doesn't work with, mostly those that had more than 3 axis or force feedback.
You should be fine.
« Reply #2 on: October 04, 2012, 11:27:48 am »
No, it's an analogue control.  It has an x-axis and a y-axis that work off potentiometers, not separate up/down/left/right inputs.
If you cut the wires, you'd have to use an A-Pac or U-HID as an interface.
The USB converter is cheaper and doesn't require any work.
wcndave
« Reply #3 on: October 04, 2012, 12:12:13 pm »
I can get this here, http://www.amazon.co.uk/PC-Arena-Male-Joystick-Adapter/dp/B003O3RDG4/ref=sr_1_1?ie=UTF8&qid=1349366589&sr=8-1
However would this still work in MAME.  Is there a driver issue, that if the flighstick is no longer supported in W7, that it will not work, or will the MAME analogue devices pick it up...
I guess there's a way to find out...
« Reply #4 on: October 04, 2012, 12:25:48 pm »
Not sure about that model.  The person that left the bad review was trying to use it with a ffb stick, which doesn't work with the one I linked either.
It has nothing to do with the joystick being incompatible with Windows 7.  Windows doesn't see the joystick, it just sees the adapter as a generic joystick.
There is nothing inside most of these old joysticks but a couple slide potentiometers and the buttons - No circuit board, no chips...nothing.
All the communication with the pc was done by the gameport interface itself.
In this case, it is done by the gameport adapter.
wcndave
« Reply #5 on: October 04, 2012, 01:23:50 pm »
Meaning it should work ;-)
