Author Topic: Couple of questions I can't find answer to.  (Read 1333 times)
nemo1966
  • Last login:March 08, 2015, 10:01:54 am
« on: September 30, 2012, 10:44:30 am »
Bit new to this, I'm an software dev with an engineering background and as such pretty hands on and a quick study.
1) When using say winxp or win7 as the machine OS... how is the shutting down of the PC done? are you setting the power options to "shut down" on pressing the power button OR the mame from end (something like mala) do this?
2) I am basically making one of these http://www.ebay.co.uk/itm/Coffee-Table-Top-Arcade-Machine-Walnut-Retro-Cocktail-Space-Invaders-Pac-Man-/221120773511?pt=UK_Video_Games_Coin_Operated_MJ&hash=item337bd33d87 I want to be able to play the same types of game + super mario bros 1 & 3 and pinball games. Will I need 4 or 8 way joysticks?
thank you
nemo
Well Fed Games
  • Last login:March 06, 2022, 07:30:46 pm
  • Delicious!
Re: Couple of questions I can't find answer to.
« Reply #1 on: September 30, 2012, 10:58:02 am »
1. Either way should work. Personally I MAME'd an existing cab, so I used the power switch method, wired the PC switch to the cab switch and just set it to shut down when I pushed it.
2. Some of those games are 8-way, so you will need 8-way sticks, or sticks that can switch between 4 and 8 way (several options for this).
Looks like a cool cocktail project!
nemo1966
« Reply #2 on: September 30, 2012, 02:29:09 pm »
Thanks for the replies - yeah I'm looking forward to getting started
thanks again
Nemo
capsule
  • Last login:June 22, 2013, 12:05:13 pm
    • caps:arcade
« Reply #3 on: September 30, 2012, 04:49:47 pm »
Both methods are available on my lastest cab. I've set mGalaxy to shutdown the PC when exiting or I can press the power button (which is relocated to the original power switch location). This way, you can't just exit the frontend and get back to Windows, were you would be stuck.
  • Last login:Today at 06:14:00 pm
« Reply #4 on: September 30, 2012, 07:06:59 pm »
Since you want to include pinball, I recommend that you look at keyboard-type encoders like the I-Pac, Mini-Pac, KeyWiz, Degenatron's AVR Encoder, etc. so you don't have to add joy2key or xpadder software.  Visual Pinball and Future Pinball aren't as flexible as MAME when it comes to configuring certain inputs.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #5 on: September 30, 2012, 10:55:38 pm »
Since you're a software dev and engineer, the Servo Stick from Ultimarc may be right up your alley.  You can program it to automatically switch from 4-way to 8-way based on what game is selected.
http://www.ultimarc.com/servostik.html
D
nemo1966
« Reply #6 on: October 01, 2012, 02:37:18 pm »
D
oooh that looks nice thanks
