Main > Main Forum
Getting geared up to start my first cab next week
MacGyver:
Also aluminum edge track for tile floors works too.
Woodshop Flunky:
--- Quote from: willybeamish on September 17, 2012, 03:23:37 pm ---
got any pics so I have an idea?
I used a straight 1/8 inch strip. The glass is heavy enough that gravity did most of the work for me.
I didn't buy it, but the mirror shop had a variety of channel that would hold the glass more securely.
For the marquee, I used 1/8 inch aluminum angle...
willybeamish:
--- Quote from: Woodshop Flunky on September 19, 2012, 06:57:59 am ---
Thanks man ;D
As far as the glass that covers the monitor would you do the same thing as you did with the Marquee??
Woodshop Flunky:
The way the marquee retaines work is that there's a top and bottom to screw to.
I could imagine the same approach working for the monitor glass... depending on how you build the area for your monitor.
The top bracket could be fixed, and the bottom one removable. When you install your glass, you slip it into the top bracket, and then place the lower bracket and attach with screws.
willybeamish:
--- Quote from: Woodshop Flunky on September 19, 2012, 01:02:56 pm ---The way the marquee retaines work is that there's a top and bottom to screw to.
Yeah im not really sure its going to fit in there and im not sure what size monitor im going to use either. Hopefully have this thing in a few days and ill take a crap load of pics, hopefully get some ideas brewing :cheers:
