Main > Everything Else
Arduino?
<< < (4/4)
HaRuMaN:
 :dizzy:
Mysterioii:
Haha I hope that's a good " :dizzy:".....   A lot of arduino projects seem to be of the "blinky lights" variety (and in fact, I've used them for that), but I think this is a good example of what those little 8-bit uC's are capable of...  and honestly I'm sure my code isn't remotely optimized... I've always been more of the "just get it to work" kinda guy...    :lol
SavannahLion:
--- Quote from: Mysterioii on September 13, 2012, 11:33:35 am ---I'm a EE but actually hadn't done much electronics-wise for several years (been doing "legacy software" support), but I used an arduino in a project I needed to do, to "get back into things" as it were.  A lot of people bash them, actually, but you have to take them for what they are.  Some people say "just use your own microcontroller, the chip itself is only three bucks", which is true, but with the arduino they're saving you some time and there's a big community out there so you can find lots of libraries and examples all over the web.  For some things, it's woefully underpowered, for some things it's fine.
A bit about my project...  We have a sewage pump station across the street from us, and "something" allows rainwater into the sewer system whenever it rains (this is not supposed to be a combined system, but things happen).  Additionally our house was actually built really too low with respect to that system...  if it rains really hard we can have water backup into the house through the plumbing.  We have a manual shutoff valve to close off the main sewer line, but of course you have to know that there's a problem.  (By the way, the sewer company is allegedly going to be reconstructing this whole system over the next few years, so the problem should go away eventually, but in the meantime I'd prefer not to get other people's poop water in my basement).
What this project does for me is:
Has 8 water sensors in various locations of my basement.
Has a buzzer acting as an alarm, located in the cold air return right at the master bedroom.
     Has a mute switch to disable the buzzer if you know there’s a problem and would rather not keep hearing the buzzer go off.
Has tilt switches on the sewer shutoff valve so I know when the valve is closed.
     Automatically removes power to the sewer ejector pump in the basement when the valve is closed to prevent it pumping waste water into the sewer line when it can’t drain out of the house.  I have built-in redundancy as a failsafe mechanism… Two tilt switches, two relays.  I have feedback signals on the relays to ensure that they are opening and closing correctly, and use the buzzer to provide audible feedback when you close or open the valve so you know the relays actuated.
Runs on battery backup from a pretty beefy UPS.
I hacked a line from the beeper in the UPS itself and ran it to an input on the microcontroller so the system knows it’s on battery backup and alerts me.
Uses a GPIO expander chip that communicates with the microcontroller using the I2C protocol because I needed a lot more digital inputs.
Utilizes a temperature/humidity sensor module.
Incorporates an external watchdog timer chip to reset the system if it should ever lock up.
Acts as a web server so I (or anyone else) can check a detailed status of the system from anywhere in the world at any time.
Acts as an email client and automatically sends me an email whenever water is detected, the valve is closed or the system switches to battery backup.
Has an RGB LED status indicator located on the device and another run up to a panel by the door from the garage, giving at-a-glance feedback to whether water is detected, the valve is closed, or everything is fine.
Additional LED indicators on the device indicate web activity, email activity and proper watchdog timer function.
The heart of the system is an arduino with an ethernet shield, but I did design and build an interface board included in the system that includes buffer circuitry for all the water sensors, the GPIO expander chip, the temp/humidity module, relay and speaker mosfet drivers, an optoisolator for the UPS “on battery” circuit, the watchdog timer chip and a voltage regulator.
Despite what I consider to be a pretty full set of features all things considering, the code compiles to only about 19KB.  The system has been running 24/7 since about February without any hiccups, and it’s correctly alerted me several times to such things as a power outage, my wife closing the sewer valve, water from a dripping cleanout valve on a water heater, etc.
I've used the arduinos for several other things, but this project was by far the most involved.  I'm pretty proud of it...  I'll try to get some pics posted later.
Holy hell dude. This is a prime example of what you should do with an Arduino. Blinking lights and game controller adapters are fine and dandy. But a full blown finished project that touches on at least a dozen different concepts is what people need to see.
But uh... A sewer valve? Is that something you had installed or the city put it in or....?
Mysterioii:
It's something the city paid for...  it is a LONG story, we had an event where water came back into the house shortly after we moved in...  The sewer district gave us some lines about "we're not responsible for record rainfall, which is what we got...", so out of the kindness of their hearts they paid for the shutoff valve to be installed.  Then it turned out that the pump station really just can't keep up with demand.  We probably should have sued, but I hate to get engaged in things like that, especially with the city.  They are supposed to be eliminating the pump station and hooking us up with a new sewer system on down the hill from us so we will no longer be the lowest spot at the end of the line...  but it's not estimated to be done until 2015.  So, for now we keep an eye on things and close that valve whenever the "high water" warning light on the pump station is going off or when we know we're going to be away from the house when rain is in the forecast.
Major pain in the butt, man...
And thanks, by the way.   :cheers:
Navigation
[0] Message Index
[*] Previous page
Go to full version
