Main > Monitor/Video Forum
TATUNG VT19726Z No Blue
smartbomb2084:
I got the CR-23 adaptor... but of course...with my luck... it doesn't fit this tube. It does fit every other tube in the building that I tried it on.
The tube I have uses this socket.... If I had the tube pinouts I guess we could make an adaptor for it.
The B+K website has a huge list of tubes and adaptors and how to interface them with their universal one but you need to know what B+K adaptor you need to use the information and this tube is not listed.
The tube number is CHUNGHWA M46AJN83X46
lilshawn:
that would be the dual focus i was talking about.
smartbomb2084:
I wondered about that...
Any idea where to get a pinout or how to find out what is the correct B+k adaptor number?
lilshawn:
sorry, i have no idea on that the socket number would be.
in the past, i have made a cable with just wires.
i remove the socket and solder the wires to the socket. (the single wire for the focus i just split into 2 wires and hook both up)
i don't have a spare dual focus socket to use but when i get one, i plan on leaving it on there.
you should be able to figure out the pinout by looking at the backside of the neckboard...(usually have them marked R/G/B/H/GND etc.)
smartbomb2084:
Thanks... unfortunately the solder side is not silk screened and the component side is not forthcoming with any info either.
