Main > Main Forum
Looking For Cab in CT...anyone having anything gutted or non working??
Pages: << < (2/3) > >>
willybeamish:
--- Quote from: DeLuSioNal29 on September 09, 2012, 06:55:00 pm ---I have a driving cab which can be modded to be a normal cab.  I'll throw in the monitor for free.  I'm in Stamford, but the cab is located in Brewster, NY (10 minutes from Danbury on the NY border).
http://forum.arcadecontrols.com/index.php/topic,122376.msg1299033.html#msg1299033
MGB, if he doesn't take your cab, I might.  I'm looking for a vertical cab for myself with a small panel for 1 joystick and 3 buttons.  What were you asking?
DeLuSioNaL29
Well im pretty much a noob with this stuff..im looking for something that would able to handle two sticks for mostly fighting games. You think this thing could be modded to fit the tankstick setup? And do you know the overall width of the cab?
DeLuSioNal29:
When I first got it, I had intended to cut a 90 degree angle so that I could simply place a control panel on it (such as an X-Arcade).  So the width of the cabinet didn't really matter, since the control panel would go past it.  It's pretty simple to do.
Here's the 90 degree angle I was going to mimic with the PP cab:
Here's the same arcade with the control panel mounted (yours would be a smaller 2 player version:
D
willybeamish:
Do you have the marquee with it by any chance ?
willybeamish:
Can you tell me if the wood is rotted at all anywhere on it ?
DeLuSioNal29:
--- Quote from: willybeamish on September 09, 2012, 08:07:10 pm ---Do you have the marquee with it by any chance ?
I have the marquee glass, so you can insert your own.  However, you are better of just measuring the glass and getting your marquee through www.gameongrafix.com (ultimate with 2 sheets of plexi option).  Then you simply sandwich your marquee in the 2 sheets of plexi and mount it in (discarding the original glass).
--- Quote from: willybeamish on September 09, 2012, 08:31:31 pm ---Can you tell me if the wood is rotted at all anywhere on it ?
It's not rotted, but in some places there is damage to the edges.  I started using bondo to fix them (works great and better IMHO than wood filler) but then I stopped working on it due to having no time.
Go to full version
