Author Topic: trackball usage  (Read 1791 times)
wcndave
  • Last login:June 10, 2021, 03:37:36 am
trackball usage
« on: September 01, 2012, 02:19:50 pm »
My trackball operates like the mouse in windows, but in games it appears to be non functional.  Any tips for getting it to work?
I am using Mame32 as my mame executable because barely anything works with the latest mame executable...
wcndave
Re: trackball usage
« Reply #1 on: September 01, 2012, 04:28:49 pm »
Ok, found a seeing in mame 32 for enable mouse, back and forward work fine, however no left and right, in gt2000
mytymaus007
Re: trackball usage
« Reply #2 on: September 01, 2012, 09:36:06 pm »
now go in the game settings area and check settings after you enables the .ini file either that you could have a trackball issue is it new
paigeoliver
  • Awesome face!
Re: trackball usage
« Reply #3 on: September 01, 2012, 09:55:17 pm »
You do know in Golden Tee you turn the man with buttons, right?
Try Centipede.
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
Re: trackball usage
« Reply #4 on: September 02, 2012, 08:00:49 am »
Try Centipede.
Yes but to select a different club you roll the ball left/right. Also to pull of some of the shots on the shot calculator you need to have the left/right movement operational.
If you're using an X-Arcade, it has a button that is a horizontal disabler. So make sure that is not turned out if that's the controller you're using
DarthMarino
  • Last login:Today at 03:38:11 pm
Re: trackball usage
« Reply #5 on: September 02, 2012, 09:05:15 am »
When you go to map your Trackball X, does anything happen? Which version of Mame32?
wcndave
Re: trackball usage
« Reply #6 on: September 02, 2012, 09:46:29 am »
actually joystick left / right seems to do the club selection.
trackball left / right is required to slice / fade etc, which is pretty critical.  At the moment I can only putt when the slope is straight, left and right is not fine grained enough.
I have bough a trackball from ultimarc, and it's connected to an ipac.  this works fine in windows.
mame32v103b (i tried mame0146b and 0143b however nothing worked, even from command line, 95% of roms failed)
I am using MaLa as the front end.
DarthMarino
Re: trackball usage
« Reply #7 on: September 02, 2012, 09:50:37 am »
What is trackball X mapped to when you go to Input (this game)?
