Author Topic: Recent Video Card supporting Component Video Out?  (Read 3151 times)
nipsmg
  • Last login:Yesterday at 12:59:59 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« on: August 30, 2012, 11:57:04 am »
I'm planning on replacing the old TV in my cabinet with a newer model that has component in.  (i'm using S-Video in currently, and it's ugly and blurry, not a huge fan).
I'd like to find a somewhat recent video card that supports 480p component out, but have been having some trouble lately.
Anyone know of any I can look at?
Thanks.
  • Last login:May 05, 2024, 08:59:50 am
Re: Recent Video Card supporting Component Video Out?
« Reply #1 on: August 30, 2012, 12:30:33 pm »
Thanks.
I don't know of any new cards, but your current card most likely supports component with an adapter pigtail.
I've never seen component-out on a video card done any other way.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2 on: August 30, 2012, 01:48:07 pm »
Right, and for old Radeon cards there was a DVI-Component dongle as well.
The problem is, I haven't seen this on RECENT cards, and I'm just wondering if there's any somewhat recent cards that support component out through a dongle or whatever.
  • Last login:Today at 07:31:30 pm
« Reply #3 on: August 30, 2012, 03:32:28 pm »
Have you looked at this adapter?
jan25th
  • Last login:November 22, 2021, 05:53:44 pm
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
« Reply #4 on: August 30, 2012, 03:37:45 pm »
Have you actually tried this? I am interested to hear (see really) the results.
« Reply #5 on: August 30, 2012, 03:45:15 pm »
Sorry, no such luck.  There are 57 reviews on Amazon, though.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #6 on: August 31, 2012, 11:06:41 am »
Yeah, I started looking at a couple of them, and the HDMI - Component adapters (that actually seem to work) seem to go for $70-$90.
However, I've seen VGA-Component adapters with 5 star reviews go for $40 ish, and I'm sure i can find a recent graphics card with VGA + DVI + HDMI out, so that may be how I have to do it.
redbeard30
  • Last login:November 23, 2023, 10:32:16 am
« Reply #7 on: August 31, 2012, 09:21:54 pm »
I believe all newer gpus will require an external VGA,hdmi,etc convert or box to use component out. I had the same dilemma and this was the info I found out. Issue is that everything is digital these days, so I believe the current video cards lack on board digital to analog convertors. The dongles  you pictured/mentioned will only work on older video cards that had a native TV out hookup. Which looks like an s-video plug minus a few pins, which is an analog source' , so then you can use a single to adapt to svideo, component, composite. So in conclusion, new video card= using an external digital to analog box, older card w/TV out= single. Hope this helps, and saves you some headache of buying something that doesn't work. I'm currently using an all in wonder at I x1800xl, runs all my name cab games fine. There are x1900xt all in wonders floating around on eBay that would run most name cab, emu stuff for cheap.
