Main > Everything Else
need help with keyboard drivers in XP
<< < (3/3)
danny_galaga:
--- Quote from: Howard_Casto on August 29, 2012, 04:25:31 am ---Well was the keyboard working in that version?
The DOS setup of xp doesn't count, that uses low-level dos drivers.
You can probably pull the drivers off of the disc... do usb keyboards work?  If so then you could just get/make a ps2 2 usb adaptor....all ipacs have a usb mode afaik.
Yes, keyboard worked properly on my XP instal (the one I caont register to another mobo). It was definitely something missing on both tinyxp and the current instal (the businessy one). It definitely wasn't a problem that USB could solve as I did the adapter and IPAC in USB mode thing. I guess you are saying it can't hurt to update the driver using the good disk. Hopefully I can find that disk again and I'll give it a shot as soon as I can (",)
I'll report back with the result.
Ah, dagnammit. It's been so long I can't remember where I left the disks :(
Navigation
[0] Message Index
[*] Previous page
Go to full version
