Main > Everything Else
SOLVED (more or less) - No embedded subtitles.....
Drnick:
See above. Meh don't worry about the Karma thing, I got 3 gold stars over there which would make me a god at the local McDonalds :) I figured it would be easier to rip the subs out then to post the disks to you from UK (Or it would have had to wait till I am over in 3 weeks, YAY annual Florida vacation coming up).
Le Chuck:
Have part three now, looks accurate. Synching it to my version (your framerate is a bit quicker). Awesome stuff so far, thanks again!
<edit>
All synched, works perfect! Can't wait to check out the other two.
Drnick:
@ Le Chuch, OK that turned into a lot more hassle then I expected (So much for CD's DVD's never going bad, It took 6 different DVD drives to rip part 1 to HDD, (It just kept failing on various files even after a major clean of the disk). But here you go I persevered and finally got the discs ripped.
Let me know if you get any problems.
Problem sorted try getting P1 again. (It was the way the disks were labled up, oddly I expected the side labled a to be a and b to be b but it was the other way round. So yeah it was a misname :)
(I suppose it may be wise of me to rip these to an MKV or something whilst I have them on my HDD, shame they are in 4:3 ratio and not widescreen)
Le Chuck:
You are awesome man! Thanks for going through all that hassle. I will get these uploaded to subscene and be sure to thank you in the comments. You have provided an awesome resource to the HI community, plus you just got Mrs. Le Chuck off of my back about finishing up the CC on her favorite movie so double kudos to you!
Drnick:
No problem, if you run into anything else you don't have CC for let me know, I may have it in my collection of movies/miniseries I am amazed that there weren't any available. I did find some, but on comparing the legit version ripped from disk and the version i found, boy oh boy, no wonder you were manually translating from Dutch.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
