Main > Main Forum
CH-926 and I-PAC 4
the_gamer:
I have another problem here: I have only 2 yellow 12V-wires from my power source left but I need to power 4 of those. Is that possible? If yes, how to connect them?
dgame:
It probably depends on the amperage of the power supply, but you could just connect two mechs to each 12v line.
It would also probably depend on the current draw of the mechs but I don't think they use a lot.
I used a 12 volt 1 amp wall adapter and connected two CH mechs and a 12v counter to the single power line and it works.
the_gamer:
I have a PC-Power supply. This one: http://www.amazon.de/gp/product/B0049HGZOK/ref=oh_details_o03_s00_i06 Sorry for the german page but I can't find it on the bequiet homepage nor on amazon.com, only the 580W one. I hope it suffices.
To connect two, they have to be connected parallel to have the 12 V, in series each would only have 6V, right?
PL1:
--- Quote from: the_gamer on September 19, 2012, 02:38:59 am ---I have a PC-Power supply. This one: http://www.amazon.de/gp/product/B0049HGZOK/ref=oh_details_o03_s00_i06 Sorry for the german page but I can't find it on the bequiet homepage nor on amazon.com, only the 580W one. I hope it suffices.
Correct. They would need to be in parallel.
12v-----------------------------------
Light Light Light Light
Gnd------------------------------------
Since the 12v lines are rated for 18A each, you can run all 4 in parallel with no problem whatsoever.
the_gamer:
Sorry for my late feedback but I had some personal problems and couldn't build faster.
I did everything like it is described here. When I turn on the pc, the CH-926 starts beeping like
hell. Only for 1 or two seconds but it doesn't sound like it should be right. The light of "indicidation"
like it is called in the manual is lighting up constantly.
Can anybody tell what is the error and how to stop that terrible beeping?
