Main > Everything Else
wiring up a 60 in 1 multiboard?
Nephasth:
Are you comfortable with wiring/electrical?
CheffoJeffo:
So, I am guessing that you don't have an existing JAMMA cabinet (if you do, then it is a cakewalk, except for having to possibly wire a couple of buttons).
First, check out what JAMMA is (first two links on that page are important for you).
Do not make a mistake on the harness connection if you are running power through the harness (but there should be some labelling on the harness to make sure that you don't screw up). If in doubt, post a picture of the harness are we should be able to tell you based on some key wire colours and grouping (grounds, +5, +12).
jspicher:
--- Quote from: Nephasth on August 20, 2012, 02:08:43 pm ---Are you comfortable with wiring/electrical?
Yes, l'm trying to learn how to hook one of these up.
jspicher:
--- Quote from: CheffoJeffo on August 20, 2012, 02:18:25 pm ---So, I am guessing that you don't have an existing JAMMA cabinet (if you do, then it is a cakewalk, except for having to possibly wire a couple of buttons).
Thanks, no existing cabinet l'm working off of here; doing it from scratch.
Nephasth:
--- Quote from: jspicher on August 20, 2012, 02:41:13 pm ---
Then this pinout should help you out quite a bit.
Pins 1-6, 27, 28, A-F, e, and f get wired to your switching power supply appropriately. Then your 60-in-1 will be powered through your JAMMA harness.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
