Author Topic: Pinball entry  (Read 62552 times)
  • Last login:Yesterday at 09:05:37 pm
Pinball entry
« on: August 17, 2012, 05:05:41 pm »
Just noticed that the Pinball entry is horribly outdated.  (Multiple dead links, etc.)
Does anybody have any objections/improvements to the following changes:
I'm thinking about choosing a better screenshot (a 4:3 table with a backglass background) and updating the text as shown below, broken out in the quote boxes for the various sections:
Visual Pinball/PinMAME
Visual Pinball (VP) is a playfield pinball simulator. It comes with a editor, so you can design your own tables. VP has a lots of well created layouts of popular pinball tables from the real world.
Visual PinMAME (VPM) is a pinball emulator. When run in conjunction with VP, VPM allows you to design and play a table that will use the actual ROM images from pinball tables. These ROM images have the table logic, sounds, and dot-matrix display animations.
The latest VP/VPM releases are all on www.vpforums.org, so the two links above direct to that homepage. (Current wiki link targets are no longer updated.)
How to install the software.
On VPForums.org, there is a "Getting Started" pulldown menu in the upper left of the page.
Download the Installation Guide, VP Installer, and all the Essential Files from the pulldown menu.
Follow the Installation Guide step-by-step.  Print a copy or have it on a nearby laptop.
VP Installer will install and configure Visual Pinball 8 (the updated VP9 physics engine can cause unusual motion in VP8 or earlier tables), Visual Pinball 9, and Visual PinMAME.
After running the VP Installer, the Installation Guide will direct you to install the latest version of VP and VPM.
If you encounter problems during the install, there is a Installation Support Forum on VPForums.org.
How to run VP on my cabinet.
You need a wrapper or cab-friendly Front-End to get this to run in your cabinet.  Visual Pinball is not cab-friendly by itself.
Hyperspin/Hyperpin links here. (not sure if hyperspin works as FE for VP/FP)
Other cab-friendly FE programs?
Shouldn't the VP/FP FE programs be listed together below the FP section?
Future Pinball
Future Pinball (FP) is the next generation Pinball Development System.  It was written by the same people behind Visual Pinball.
It allows you to design and play your very own pinball simulation in True real time 3D.  It uses Advanced Physics to provide the best possible Simulation of a true to life pinball machine.
Future Pinball does not utilize VPM, nor does it have the option to use pinball table ROMs.  Any information that would normally be stored in the ROM is written into the script or stored in a library file.
How to run FP on a cabinet.
You should download the lastest version (from 1.5.2 or above) to get this to work on your cabinet, if you are using the gameport. But if you use a keyboard hack, it may lose focus at the startup, so you need a wrapper. This wrapper should also work for cabinets, using gameport.
The wrapper link is dead, not quite sure what point the rest is trying to get across.
Combine this section with the VP FE section above?
About Sticky Keys
Future Pinball allows table creators to use two special keys that can be fully remapped by the application.
But some table authors have overlooked this feature, and used stickykeys instead.  This is generally not good for use on a cabinet, and thus must be fixed.  It is often very easy to fix these by just looking at the script.  Find the keyname (like "h"), and change it.  Some creators have even defined these stickykeys at the top of the script, so you only need to change it once.
Is this section needed?  In-depth troubleshooting like this might be better refered to VPForums.
Is stickykeys supposed to be one word or two?
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re: Pinball entry
« Reply #1 on: August 17, 2012, 09:29:54 pm »
No objections here, love having folks update the wiki. :)
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Re: Pinball entry
« Reply #2 on: August 18, 2012, 05:01:17 am »
Any idea what this wiki login error message means?
Unable to view external table
MySQL Error Number: 1054
MySQL Error Message: Unknown column 'memberName' in 'field list'
saint
Re: Pinball entry
« Reply #3 on: August 18, 2012, 09:04:42 am »
Mmm something broken in our move. I'll ask Sirwoogie to look at it.
--- John St.Clair
     Project Arcade 2!
Re: Pinball entry
« Reply #4 on: August 20, 2012, 08:44:42 am »
Is wiki login working for anyone else yet?
Tried to login and got this.
Login error:
You have not specified a valid user name.
saint
Re: Pinball entry
« Reply #5 on: August 20, 2012, 08:59:57 am »
Oops, sorry I didn't update. There is a problem with the logins related to the upgrade/move. We're (read that as sirwoogie since I just tend to break things when I go behind the scenes) having to rework the Wiki. I will update when that is working again.
--- John St.Clair
     Project Arcade 2!
Re: Pinball entry
« Reply #6 on: October 01, 2012, 05:33:45 am »
One month bump + progress check.
Thanks in advance for any updates.   :)
Re: Pinball entry
« Reply #7 on: November 01, 2012, 09:54:09 pm »
One Two month bump + progress check.
Re: Pinball entry
« Reply #8 on: December 01, 2012, 02:25:04 pm »
One Two Three month bump + progress check.
Not to be impatient/pushy, but is fixing the Wiki logins still somewhere on the "to do" list?   :dunno
Re: Pinball entry
« Reply #9 on: January 25, 2013, 02:30:08 pm »
One Two Three Five month bump + progress check.
The question still remains unanswered -- Is fixing the Wiki logins still somewhere on the "to do" list?   :dunno
With all due respect, Saint -- Sirwoogie hasn't logged in since 9 Nov and you never responded to my 5 and 15 Dec PMs. (Follow-up message sent today.)
If you're already working it, a simple "I'm on it" would be appreciated.
If not, why not?
« Last Edit: January 25, 2013, 03:16:45 pm by PL1 »
Re: Pinball entry
« Reply #10 on: March 15, 2013, 09:46:03 pm »
I've had a sudden urge to work on the wiring page, but...
Re: Pinball entry
« Reply #11 on: March 15, 2013, 10:46:34 pm »
And that brings us (a couple of days early) to the One Two Three Five Seven month bump + progress check.
With all due respect, Saint -- Sirwoogie still hasn't logged in since 9 Nov and you still haven't responded to my 5 Dec, 15 Dec, or 25 Jan PMs.  :angry:    :censored:   :angry:
If you can't fix this login problem, Saint, it is time to get your ass in gear and find another IT helper who can.
As before, if you're already working it, a simple "I'm on it" would be appreciated.
If you're not looking for a helper, why not?
If you are looking, what would it hurt to say so?
Your giving me the silent treatment in this thread is a pretty crappy thing to do IMNSHO.   :badmood:
Normally I'd only address a lack of common courtesy and manners like that in a PM to avoid needlessly airing dirty laundry, but . . . *sigh*.  :banghead:
spoot
  • Destroyer of electronics
Re: Pinball entry
« Reply #12 on: March 16, 2013, 10:31:07 am »
I've not tried to edit wiki.....user/password supposed to be as same as the forum?  Would think easy fix?   :-\
Re: Pinball entry
« Reply #13 on: March 16, 2013, 02:45:22 pm »
Apparently, Sirwoogie agreed in this PM on August 19th.
Quote from: sirwoogie
We're aware of it. We'll be fixing it in the next few days.
Unfortunately, he didn't fix it before he dropped off the grid in November.
Not even sure if he got around to trying to fix it.   :dunno
I just hope that Saint reaches the fifth stage in the Kübler-Ross model sometime soon, but it appears as though he's stuck in the first stage. (Hint: It's not just a river in Egypt.)   >:D
Re: Pinball entry
« Reply #14 on: March 16, 2013, 04:30:20 pm »
Saint,
Have you looked at this page?
Looks like it may have fixes for several causes of the error message coming up when trying to log into the Wiki.
saint
Re: Pinball entry
« Reply #15 on: March 20, 2013, 07:26:28 am »
A PM would probably have been more effective :) Anyone good with Lighttpd, SMS, and wiki wrangling interested in taking a look? I will look at the link you posted about the logon error. Thanks!
--- John St.Clair
     Project Arcade 2!
saint
Re: Pinball entry
« Reply #16 on: March 20, 2013, 07:38:46 am »
post_max_size and upload_max_filesize in php.ini are not set too high. 8M and 2M respectively. I will keep looking.
--- John St.Clair
     Project Arcade 2!
saint
Re: Pinball entry
« Reply #17 on: March 20, 2013, 08:06:02 am »
One of the problems is the integration between SMF and the wiki is an old, outdated, no longer supported mod. Thoughts on dumping the integration and having a separate username/password on the wiki vs. trying to fix this link?
--- John St.Clair
     Project Arcade 2!
Re: Pinball entry
« Reply #18 on: March 20, 2013, 08:36:45 am »
I like it when they update the front page. /late burn
As for the integration, cant you just dupe the username/passwords for the wiki (so I can be sure Im Malenko on there before XuiceBox signs up as me)?
I should prolly update the wiki, give me something to do at work besides get moderated on the forums.
Re: Pinball entry
« Reply #19 on: March 20, 2013, 04:24:39 pm »
I am glad to see this is back on your radar -- which is why I PM'd you those times.
Hopefully someone who knows what they're doing can get this sorted.
Seems like there must be at least one SMF2 forum out there that has Wiki integration working.   :dunno
saint
Re: Pinball entry
« Reply #20 on: March 20, 2013, 04:56:23 pm »
Hm. A PM would not have been more effective :)  Due apologies.
--- John St.Clair
     Project Arcade 2!
Re: Pinball entry
« Reply #21 on: April 20, 2013, 10:00:21 am »
Eight month bump.  Looking for someone who knows the elusive art of wiki wrangling and/or input on the question of separate logins.
My 2 cents:
Keep looking for someone who knows how to integrate the 2 logins, since that is the ideal outcome.
While we're waiting (. . . and waiting, and waiting. . . ;D), establish separate logins for the wiki because it desperately needs attention.
-- Option 1 - User PMs Mod to create login.  Mod sends PM with a temp password.
-- Option 2 - Allow users to create login/password.
If anyone notices their (or someone else's) wiki login being hijacked, PM a mod who can set a different wiki password and PM it back to the user's forum account, allowing the actual user to regain control.
The sad truth is that the number of contributors/editors will probably be small enough to make either option manageable, but I'd love to be proved wrong on this.   >:D
« Last Edit: April 20, 2013, 11:05:01 am by PL1 »
Re: Pinball entry
« Reply #22 on: May 09, 2013, 11:32:05 am »
Anyone have any other options they'd like to suggest for getting Wiki-logins working again?
Does anyone like either of the options listed above or are they unworkable for some reason that I'm missing?
spoot
Re: Pinball entry
« Reply #23 on: May 09, 2013, 12:27:22 pm »
As you say, I'd guess there would be few accounts who'd want update ability.  As such, pm'ing a mod to create account doesn't seem far fetched imho.
saint
Re: Pinball entry
« Reply #24 on: May 12, 2013, 09:36:12 pm »
In the interest of not totally ignoring folks - I'm in the absolute worst part of the year in my work and personal life. Anything that's not a few button clicks gets back burnered. Come July I get a breather for a couple of months. If SirWoogie isn't available to fix things before then I'm of the mind to just install a brand new Wiki with its own security credentials, and migrating everything over. Do we need secure editing, or should it just be open?
--- John St.Clair
     Project Arcade 2!
Re: Pinball entry
« Reply #25 on: May 13, 2013, 11:59:23 am »
Open should be fine, just make sure your archive changes to make it easy to roll pages back.
Re: Pinball entry
« Reply #26 on: May 13, 2013, 04:23:22 pm »
I like the last edited by tag so if something is wonky or I want to add to I know who to shoot a pm at, that aside I'm fine with open if there is a way to make it attributional.
  • Last login:Yesterday at 12:31:00 pm
Re: Pinball entry
« Reply #27 on: May 13, 2013, 04:33:25 pm »
I think you should leave it broken to see if PL1 has a coronary when it reaches a year's time.  >:D
Re: Pinball entry
« Reply #28 on: May 13, 2013, 08:24:25 pm »
:laugh2:
Gray_Area
  • -Banned-
  • -Banned-
Re: Pinball entry
« Reply #29 on: May 15, 2013, 06:53:01 pm »
-Banned-
Re: Pinball entry
« Reply #30 on: July 21, 2013, 03:35:07 pm »
Eleven month bump -- how are things going, Saint.   ;D
Re: Pinball entry
« Reply #31 on: July 24, 2013, 12:48:23 pm »
Re: Pinball entry
« Reply #32 on: July 31, 2013, 12:08:41 pm »
::) Yeah . . . I guess I'm just getting too uppity by waiting several months to do a friendly bump on a thread concerning an issue that Saint said here that he wanted to fix but wouldn't have time to work on until . . . July.   ::)
[/sarc]
BTW "lowering your standards" = surrender and that's not my style.   8)
« Last Edit: July 31, 2013, 12:13:47 pm by PL1 »
Re: Pinball entry
« Reply #33 on: July 31, 2013, 12:18:43 pm »
You know, Scott, you could probably create a free Wiki somewhere and just have Saint link to it. Probably be quicker.
Re: Pinball entry
« Reply #34 on: August 19, 2013, 07:18:03 pm »
1 year bump.
Good news: i haven't had a stroke (yet).   :lol
Not-so-good news: So far, no word on how (or if) the wiki fix is proceding.  Sirwoogie has only logged in once since November last year AFAIK.
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
Re: Pinball entry
« Reply #35 on: August 20, 2013, 07:24:06 am »
Good news indeed :-)
This basically means that we shouldn't expect an update anytime soon. AFAIK Sirwoogie did the technical stuff on the server? Even switching back to basic Wiki-native authentication shouldn't take too much time, and at least makes the wiki usable again.
Re: Pinball entry
« Reply #36 on: August 20, 2013, 08:53:48 am »
That takes us back to reply 21 in this thread.
What say you to this proposal, Saint?
- Separate logins for Forums and Wiki.
- Archive changes enabled to allow easy rollbacks if needed.
- Select a mod/mods to handle a WikiMod account similar to the way the UCA (User Choice Award) account works now.
- Users PM the WikiMod account to establish a login with the same username as in the forums. (modded username if the "underscore bug" is a problem?)
- WikiMod sets up login and sends confirmation PM with temp password.
powtripp
  • Last login:September 12, 2013, 10:02:09 pm
Re: Pinball entry
« Reply #37 on: August 28, 2013, 04:41:02 pm »
This is what you need:
https://github.com/SimpleMachines/smf-mw-auth
The php code for the authentication extension file was recently updated 19 days ago and should be good to go. Script authored 4 days ago.
The installation instructions are very simple.
Now you just need to contact someone with FTP access ;).
« Last Edit: August 28, 2013, 04:49:57 pm by powtripp »
Re: Pinball entry
« Reply #38 on: September 20, 2013, 07:12:45 pm »
Triskadekaphobics beware! :scared
13-month bump.
Saint -- I replied to your last PM on August 24th at 11:37:43 am and sent a follow-up email with the same text about a week later, they must have been lost in the bit-bucket again. :badmood:
Also, any comment on Powtripp's github link?
Re: Pinball entry
« Reply #39 on: October 18, 2013, 04:07:59 am »
14-month bump.
Any progress?
Still no replies or feedback on the last bump.   :badmood:
