Author Topic: P360 and qbert  (Read 1698 times)
jdjuggler
  • Last login:May 08, 2022, 10:54:37 pm
  • Hurray! I don't have pockets for quarters anyway!
P360 and qbert
« on: July 22, 2012, 02:01:20 pm »
Sorry to bring up an old topic, but I'm trying to get my Happs P360's to work well with qbert.  I have changed the qbert.ini file several times and it does not appear to make any difference.  I am currently using
joystick_map             444555888.444555888.444555888.555555555.555555555.555555555.222555666.222555666.222555666.
Even if I make it all 5's, it still acts the same way.  Any idea why I can't get this mapping to work?
JD
jdjuggler
Re: P360 and qbert
« Reply #1 on: July 27, 2012, 05:10:50 pm »
bump
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 07:25:45 pm
Re: P360 and qbert
« Reply #2 on: July 27, 2012, 10:04:06 pm »
probably not what you're looking for but,
I attach LEAF Switches to my P360 installed 45deg for Q-Bert/Congo Bongo etc...Games. It works great.
It's like having that other joystick installed in my panel but piggyback with my p360.
It's wired separately from the p360.
Here is a pic.
Free VGA Breakout Cable
Thenasty
Re: P360 and qbert
« Reply #3 on: July 27, 2012, 10:04:53 pm »
forgot to mention that I had to change the joystick with longer shaft.
jdjuggler
Re: P360 and qbert
« Reply #4 on: July 29, 2012, 01:09:18 am »
That looks like a great idea.
I'm guessing you just changed the 4 directional keys for qbert and congo bongo to some other keys, so that hitting these during other "8-way" games does not create a problem???
Also, where did you get the longer shafts?
Thanks,
JD
Gray_Area
  • -Banned-
  • -Banned-
Re: P360 and qbert
« Reply #5 on: July 29, 2012, 02:21:57 am »
You have to test/change the settings in MAME after each map change, yo, to make sure the axis are right for each direction.
U-hnhh. Just buy a Sanwa stick.
-Banned-
jdjuggler
Re: P360 and qbert
« Reply #6 on: July 29, 2012, 02:40:13 pm »
So, with all of this I may just get the Ultimarc U360's.  And, I believe the mapping software will allow me to set these to do the diagonals for qbert and congo bongo.  And, as I've read, I get the advantage of analog control too.  I'm assuming I can hook these up to my keywiz?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: P360 and qbert
« Reply #7 on: July 30, 2012, 11:19:39 am »
The Ultrastik 360 can be connected to an interface but there is usually no need to as it plugs directly into USB.
