Author Topic: Turn your old PC power supply into a DIY arcade power supply (for Jamma)  (Read 11492 times)
  • Last login:October 20, 2023, 11:39:06 pm
Hi all,
I was doing some research on how to splice a power supply and came across this interesting tutorial on how to change your PC power supply into and arcade power supply.  Just thought I'd share.
http://web2.murraystate.edu/andy.batts/ps/PowerSupply.htm
DeLuSioNaL29
MadMagpie
  • Last login:May 05, 2014, 08:41:23 pm
Nice one, thanks for the share.
  • Last login:April 30, 2024, 07:38:23 am
bookmarked  :cheers:
SavannahLion
Before you jump in on that....
http://www.arcaderestoration.com/index.asp?OPT=3&DATA=647&CBT=4
Then there's the -5v rail if your board needs it. I remember a really great post somewhere about this -5v rail but I can't seem to find it (or I'm too lazy I guess). But from what I recall, even the cheapest PSU from Happs Controls offers about 1A on the -5V rail. Looking at the cheapest PSU at newegg, there is no -5V rail. Checking out a pricy $300+ model with a whopping six different +12v rails and ZERO -5v rails.
Not saying every board requires -5v, but if you need it... well, you're still SOL I guess.
I hacked a older PC PSU and I don't really use it for much on my test bench. There are limitations to what you can do, even with a PC PSU and various combinations of your 3.3, 5, and 12v rails. It's probably to do with the fact that I don't really like mucking with circuits plugged into the wall, even if it's through a transformer.
« Last Edit: July 21, 2012, 01:42:33 am by SavannahLion »
Franco B
I use an ATX PSU on my wiring bench for a -5v, 5v and 12v source for powering/testing various looms etc but I wouldn't suggest using one as a power source for arcade boards.
I say this because that type of PSU has no control for the 5v which tends to need to be tweaked to suit each PCB due to the rise/fall in voltage due to the current draw of different boards. Running a PCB with the 5v too high or low can cause issues when running the game or could even potentially damage it.
In regards to the -5v:
Quote from: Wikipedia
Pin 20 (formerly −5 V, white wire) is absent in current power supplies; it was optional in ATX and ATX12V ver. 1.2, and deleted as of ver. 1.3.
Yenome
  • Last login:April 12, 2024, 01:03:06 am
  • Punch a fish. Make a wish
i would have to agree with franco. i have heard of MK being one board that is real picky bout the -5 being set just right. but dam where was this link when i was wanting to make sure the monitor not working was a monitor problem and not a psu problem.
Thanks for the caution, I'll stick with the real deal.
darthpaul
  • Last login:November 23, 2022, 07:34:53 pm
  • Join, It's your duty
Using two of those, one for my rotation motors and the other for my LEDS.
Automated Cabinet
Nintendo Pi
PiCubed
