Main > Everything Else
A strange HD crashing....
Gray_Area:
--- Quote from: lilshawn on July 29, 2012, 01:18:30 pm ---harddrives do some stuff at startup...at startup if the drive fails to spin up to proper speed (either due to bad berings or stiction or possibly low current situation) the harddrive will pause for a few seconds and attempt it's startup again. I have the feeling the "flicking of the cable" is just a coincidence.
This drive's SMART info will probably be marked as a bad drive now since the spinup retries and attempts is now artifically high. It might still be good, just make sure it's backed up and keep an eye on it maybe run some diagnostics on it once you figure your system has stabilized.
I don't know. Every time it happened, if I flicked the cable, the drive would audibly start up. I thought of troubleshooting the adapter as shmokes suggested, but I thought it easier just to replace the unit and know for sure it wasn't anything in that chain. Will do some disc diag some time, I guess. I'm so lazy!
Navigation
[0] Message Index
[*] Previous page
Go to full version
