Main > Everything Else
A strange HD crashing....
shmokes:
You've explained that a faulty power supplies can cause erratic behavior. And you've described how an underpowered power supply can be similarly problematic. And I absolutely agree on both accounts. But I don't see how it could cause a problem that could be reliably fixed by jiggling the power connector where it plugs into the hard drive.
lilshawn:
--- Quote from: shmokes on July 21, 2012, 11:06:51 pm ---You've explained that a faulty power supplies can cause erratic behavior. And you've described how an underpowered power supply can be similarly problematic. And I absolutely agree on both accounts. But I don't see how it could cause a problem that could be reliably fixed by jiggling the power connector where it plugs into the hard drive.
god's plan? :dunno
ark_ader:
Shmokes is trying to impress you that he got his A+. :laugh2:
Well done Shmokes, hope it fares you better than that worthless law degree. :applaud:
lilshawn:
--- Quote from: lilshawn on July 22, 2012, 05:23:57 pm ---
god's plan? :dunno
--- Quote from: ark_ader on July 22, 2012, 05:50:20 pm ---Shmokes is trying to impress you that he got his A+. :laugh2:
Is this a bad time to tell everyone i'm atheist? Guess it would have been funnier if everyone knew. Can we start over?
shmokes:
Ark, your profession is supposedly IT. Your diagnosis is power supply. Shouldn't you be able to defend your analysis? How did you reach that diagnosis? My IT qualifications are irrelevant. You could have your CCNA and MCNE and you'd still be wrong. Unless you're right, of course, but you seem disinclined to explain how you reached your conclusion.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
