Main > Monitor/Video Forum
Newbie TV walkthrough, please!
Pages: << < (58/59) > >>
Paradroid:
--- Quote from: dmckean on May 20, 2015, 11:46:10 pm ---After weeks of searching for any TV that size with component inputs I've found a Phillips 20PT643R01. Is there anything wrong with this particular set or Phillips sets in general?
Philips are a good, solid brand. You can't go too wrong there.
Paradroid:
--- Quote from: Amra on April 30, 2015, 10:11:05 pm ---I modified your circuit to be a bit simpler
Thanks for this Amra. I finally got around to trying this out last night using a piece of Veroboard to build the circuit. The old circuit I had been using successfully for VGA to SCART cables wouldn't work properly with my direct to Jungle IC hacks but this one does! Woohoo! ;D This means I can eliminate the UMSA and Extrons from my chain and make standalone RGB input hacks for my TVs instead.
dheck:
Guys can you help me out?  Using the CVS287 I followed the schematic posted below.  I am using an ATI4350 video card with CRT EMUdriver connected to a 27" SONY CRT.  The second monitor shows up fine in Windows 7.  Below is the image I am getting.  It's hard to make out but that is the Windows 7 background extended onto the SONY CRT.  Where should I even start diagnosing.  I checked my wiring and everything seems to be correct.  Any advice on where to start?
lilshawn:
you may have to tie ground to pin 17/18 of the scart socket as well.
dheck:
I think I just figured out what I missed.  I did not ground pins 5,6,7,8,9 and 10 on the dsub.  I will try that and see how it goes.
Go to full version
