Author Topic: Getting a trackball to work with Golden Tee and other games?  (Read 1555 times)
TheShaner
I cannot seem to get my trackball working inside of Mame.  It works to move the mouse pointer outside of MAME but nothing inside.  I have multimouse set to 1 inside of the mame config, and I looked into the settings in mame but couldnt see anything that needed changing.  Anyone know what I might be able to do to get it working?
Re: Getting a trackball to work with Golden Tee and other games?
« Reply #1 on: July 05, 2012, 11:20:58 am »
Tab -> Input (General) -> Player 1 Controls (P2, P3, P4 as needed) -> Set Track inputs  ???
No trackball here, so this is an assumption...
TheShaner
« Reply #2 on: July 05, 2012, 11:28:07 am »
I was sitting in that area a little earlier, but the issue is that it already says mouse1 and joystick.  On Track2 it refers to mouse2 axises.  So, it seems like it should work.  Unless I need to designate the trackball as Mouse 1 or two somewhere in windows, not sure.
« Reply #3 on: July 05, 2012, 02:08:40 pm »
Did you set the input? Or just check to see what it said? Highlight the input and hit enter, then spin your track ball (x or y axis accordingly). Also, make sure the game specific inputs are the same as your general inputs (in case they were changed at some earlier point in time).
« Last Edit: July 05, 2012, 02:11:34 pm by Nephasth »
Dawgz Rule
  • Last login:Today at 08:25:20 pm
  • The more people I meet, the more I like my dogs
« Reply #4 on: July 05, 2012, 02:15:13 pm »
Check your mame.ini file to ensure your mouse is enabled.  Should read "mouse 1" under the input options.  Also try setting multimouse to 0 instead of 1
« Reply #5 on: July 05, 2012, 02:47:04 pm »
Was looking at your project thread, in the last pic it looks like you have a wired keyboard and mouse hooked up to your machine. I think this might be a mouse id issue... Does your wired mouse do anything control wise with the games in question?
TheShaner
« Reply #6 on: July 05, 2012, 02:52:25 pm »
The mouse was turned off in the mame.ini.  That did the trick!  Thanks!
Dawgz Rule
« Reply #7 on: July 05, 2012, 04:09:23 pm »
Cool deal.  :cheers:
