Main > Main Forum
soldering tips needed
Nephasth:
Also, if it's easier for you, the resistors don't need to be soldered directly to the LEDs. They can be several feet away from the LEDs in the circuit in a more convenient location.
tony.silveira:
--- Quote from: Nephasth on July 03, 2012, 01:18:49 pm ---Also, if it's easier for you, the resistors don't need to be soldered directly to the LEDs. They can be several feet away from the LEDs in the circuit in a more convenient location.
didn't think of that either, sheesh! i can just run wire to my ledwiz and have the resistors installed in the screw terminals and then solder the wire to that.
thanks for the input guys!
knave:
Nobody's gonna tell him that he can buy new tips at Radio Shack? :lol
Mysterioii:
No prob. BTW even if I'm just soldering wire to an LED or other component, I like to tin the wire first then hook it with the needle nose pliers just like if I was soldering two components together. Mechanical connection... that's how I was taught, and it stuck... :lol
alfonzotan:
There's always Old Faithful when it comes to soldering tips: "The bigger the blob, the better the job!"
