Main > Main Forum
soldering tips needed
tony.silveira:
--- Quote from: knave on July 03, 2012, 01:34:25 pm ---Nobody's gonna tell him that he can buy new tips at Radio Shack? :lol
:laugh2:
compute:
I'm a big fan of those "handy helper" things with the two aligator clips that can be positioned. If I need more hands, I'll bring in a hemostat or two to hold the thing together while I solder.
PL1:
+1 to solid mechanical connections and tinning your wires before bending and soldering them.
If you don't have rosin core solder, a little rosin soldering paste flux is your friend. You can apply it with a toothpick or dip the wire/component into the container.
Make sure you get flux like Radiio Shack P/N 64-022 which is labeled "For electrical and electronic applications." DO NOT USE ACID FLUX which is intended for metal repairs.
Clean up the joint area afterward with a little isopropyl alcohol on a brush or cotton swab.
Also, if the components don't reach a high enough temperature, you can get a cold solder joint.
General soldering info on power ratings, tip selection, and flux.
P.S. In case anyone misunderstood Alfonzotan: "The bigger the blob, the better the job" is an old soldering joke.
shponglefan:
That was my first thought when I saw the thread too. ;D
eds1275:
Me 3. I actually just looked all over town for tips that fit my iron and couldn't find any in stock, so I busted out the dremel and ground my old one back into a point. It worked like new. I still ordered some new ones online when I got home though.
