Main > Everything Else
I'm looking for a theatre display again.....
<< < (5/30) > >>
ChadTower:
--- Quote from: CCM on July 02, 2012, 03:12:28 pm ---Huh?   So hang a flat screen on the wall in that same small room, and your view will still be blocked when people walk in front of you...
Think about this for a second.  With a projector they often can't walk behind you either.
Gray_Area:
--- Quote from: crashwg on July 01, 2012, 10:39:23 pm ---I'll throw in my 2¢ and say some people are prone no nausea induced by DLP's "rainbow effect."  My wife is one of those people so our next projector will have to not be DLP.
By single-chip DLPs. I wonder whether the greater apparance of this effect to some is due to the pattern of a person's eye movements.
A little in contrast to the nature of this forum and all, but I don't want to put stuff together. The bulk of the work in this....project....may be as much as wall-mounting the display, but will probably be hooking it up to a computer and running an ethernet cable through the wall.
So what 50" plasmas do you recommend?
shmokes:
Panasonic is best (RIP Pioneer).
saint:
--- Quote from: ChadTower on July 02, 2012, 03:15:59 pm ---
Have to be a pretty funky room setup for that. Ceiling mounted projector properly spaced really doesn't have that issue any more than a tv on the wall. If you can't mount it properly, for instance if you're putting it on a table, then yeah, different story.
lilshawn:
the gamut on some plasmas are terrible.
(http://forum.arcadecontrols.com/index.php?topic=116768.msg1238418#msg1238418)
remember?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
