Main > Everything Else
Help - need a camera or video camera with specific criteria
<< < (2/2)
Le Chuck:
Are you going to make two units so it works from either side?  That would be pretty awesome.  That solid object wouldn't be a chest for a zombie would it?
saint:
--- Quote from: Le Chuck on June 29, 2012, 06:18:09 pm ---Are you going to make two units so it works from either side?  That would be pretty awesome.  That solid object wouldn't be a chest for a zombie would it?
I'll never tell :)
saint:
--- Quote from: pinballjim on June 30, 2012, 01:14:40 am ---Iphone?
My backup plan is an iPhone with iPad using Facetime. Tested and working, but the form factor of both of them is difficult to use. Also concerned about the touch screens and buttons getting accidentally pushed and me not noticing. Still good call.
saint:
--- Quote from: pinballjim on June 30, 2012, 10:48:21 am ---Well, I was thinking more of using the video camera on the phone via output cable to your display.  Since the camera is rear facing you could mount the phone such that the screen shouldn't get accidentally touched.
You may have to jailbreak your device to enable TV output while that camera app is running.  You can get an app off Cydia called Resupported that'll let you use the cheaper composite cables.  I've only ever used that functionality to get a hall of mirrors effect on my living room TV (fun for 5 seconds).
Then just use some cheapie LCD for the front.
 :dunno
Ah! You da man! I will investigate that, that's perfect. Thanks!
Navigation
[0] Message Index
[*] Previous page
Go to full version
