Author Topic: Pulling pins out of a connector...  (Read 1159 times)
Fred Smythe
  • Last login:July 28, 2018, 06:57:27 pm
  • Here is your FIRST subject...
    • Chez Fred
« on: June 22, 2012, 05:44:23 pm »
This is a shot of the type of connector that plugs into my Oscar Controls Vortex spinner:
The problem is that the harness it's attached to (for an older Mini-PAC) has the two signal pins backwards. (When I spin it to the right, the Windows cursor goes left, etc.) For various reasons I would prefer to fix this in hardware over software, so I need to swap the blue and green wires.
Simple question: what's the best (non-destructive) way to get those wires pulled out of this sort of connector? I tried a straight pin pushing down the barb, but I don't think I got enough purchase. Is there a better tool? (Really, there has to be a better tool; the question is, what is it?) Or would I just be better off finding a couple more of those connectors (though I have no idea what size it is or what to ask for; are they standard?) and building an adapter harness?
Thanks much!
-- Chris
« Last Edit: June 22, 2012, 05:56:30 pm by Fred Smythe »
Chris Lemon
clemon79@outlook.com
http://fredsmythe.com
Peja
  • Last login:June 09, 2015, 04:48:22 pm
Re: Pulling pins out of a connector...
« Reply #1 on: June 22, 2012, 06:09:23 pm »
While I am sure there is a tool out there that will do it, I am also not sure what it is either.  In the past I have used small flat head screw drivers from the mini tool kit.  Worked just fine.
How about cutting the wires and crossing them with some butt splice connectors?
Peja
Fred Smythe
    • Chez Fred
« Reply #2 on: June 22, 2012, 06:12:39 pm »
Yeah, I may try that. Did you just press and pull?
I could do that too, yeah, but...ugh. The wiring inside that panel is already enough of an utter kludge...aesthetically it offends me to make it worse. :)
Chris Lemon
Franco B
« Reply #3 on: June 22, 2012, 06:16:47 pm »
It looks like a typical 0.100" pitch 4 position Molex KK type connector to me.
You should just be able to push the barb down with a small screwdriver or pin to release it.
Don't pull on the wire whist pushing down on the pin, pull on the wire just afterwards. If you look closely you should be able to see when the barb is below the level of the housing and can be released.
If you do push the barb too far through the crimp you can sometimes push it back through from the other side so you can reuse it.
« Last Edit: June 22, 2012, 06:18:59 pm by Franco B »
  • Last login:Today at 07:31:30 pm
« Reply #4 on: June 22, 2012, 06:21:54 pm »
I think it also helps to push the wire and pin in slightly before you push down gently and slide it out.
Peja
« Reply #5 on: June 22, 2012, 06:23:51 pm »
Yep, just like Franco  and PL1 said......I pressed the barb down and then pulled out.  Not sure if you may have to put a needle in the front of the connector to raise the bottom up a little bit, but its worth a try.
I agree with you on the clutter look.  However, Sometimes if you get too rough with it you can break those barbs off and then you're worse off then if you would have just crossed the wires.  Still give the screw driver a try though.
Good Luck,
Peja
Fred Smythe
    • Chez Fred
« Reply #6 on: June 22, 2012, 06:39:28 pm »
Nope, screwdriver did the trick. I think I just wasn't giving it uniform (or enough) pressure to get the barb down properly. (And once they were out it was easy to pry them back into a usable state again before returning them to their proper homes.
So all good, and thanks again! :)
Chris Lemon
