Author Topic: MAME not recognizing hacked USB gamepad?  (Read 1928 times)
bsktbllmn23
  • Last login:November 14, 2015, 11:36:34 pm
« on: June 18, 2012, 12:19:26 pm »
I hacked a game pad from Amazon, thread here http://forum.arcadecontrols.com/index.php?topic=120797.0.
The issue is that Windows sees all the buttons (when touching the wires together since i haven't mounted the buttons yet), but when i get into MAME32 and open any game, hit tab to get to menu, and try and adjust controls, the game pad doesn't register any of the wire touches...
I got frustrated and haven't tried to configure the controllers in my other emulators yet, but MAME is the one that I really wanted to get working.
Any ideas? did i miss something when doing my research and not configure something right? or have i just messed up the game pad?
I did get MALA to recognize the game pad and had it configured to work basically, and since windows recognized all the button presses i just assumed that MAME would work too.
paigeoliver
  • Awesome face!
Re: MAME not recognizing hacked USB gamepad?
« Reply #1 on: June 18, 2012, 12:37:52 pm »
Your gamepad probably isn't working because the default mame configuration has gamepad and mouse control turned off for some ridiculous reason.
crumptinite
  • Last login:September 06, 2017, 01:35:19 pm
« Reply #2 on: June 20, 2012, 11:44:05 am »
Have you tried the JoytoKey program? "keyboard emulator for joysticks.
It converts joystick input into keyboard input" I used this for some of my pc games that don't accept controllers. http://joytokey.webs.com/
capsule
  • Last login:June 22, 2013, 12:05:13 pm
    • caps:arcade
« Reply #3 on: June 20, 2012, 02:18:18 pm »
Yep, very useful for frontends not handling gamepads either (like mGalaxy)
ark_ader
  • I glow in the dark.
« Reply #4 on: June 20, 2012, 05:19:10 pm »
Just remap it in Mame.cfg
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
« Reply #5 on: June 20, 2012, 06:41:15 pm »
I use Mame32 Plus and to change the configuration of the gamepads under; "OPTIONS" then "DEFAULT GAME PROPERTIES" and finally "CONTROLLERS" tab. Just make sure you have enabled joystick input and that the proper controllers ID is set.
