Author Topic: General question regarding later versions of Mame  (Read 1760 times)
JayB
  • Last login:January 25, 2013, 06:11:59 pm
« on: May 22, 2012, 01:01:00 pm »
At the moment I have v113 running on a Pentium 4 3ghz, fine. I wanted to get rid of the nag screen (left/right) and found a version 139 which had removed all the loading and nag but, half the games are missing files. I presume I can't get the no nag with 113?
Is the latest version of Mame 146 noticeable in terms of cpu useage compared to what I have? Mainly classics and some 90's games so don't want to upgrade the machine really. Just don't want to go down one road and find it's created new problems  :dizzy:
DrChek
  • Last login:March 20, 2024, 10:41:01 pm
Re: General question regarding later versions of Mame
« Reply #1 on: May 22, 2012, 01:18:03 pm »
Latest version will be more demanding.
You can get no-nag for 113, you just might need to compile it yourself. There is a sticky thread in the Software forum that tells you how.
I personally run 106 on all my classic cabs since MAME took its biggest performance hit startling with the next version.
JayB
« Reply #2 on: May 22, 2012, 01:23:50 pm »
Thanks for the reply DrChek.
Really? That would be great if so as I have sorted out all my games the last few weeks and this problem with 139 has really screwed me. I didn't realise the no nag had been implemented in earlier versions so many thanks for this  :applaud:
I'll take a look at the sticky and fingers crossed  :cheers:
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: May 23, 2012, 04:08:04 am »
Yes, and I've mainly stuck back there for similar reasons.....but now, too many games I play are getting good not to be seriously interested in using current MAME.
-Banned-
DrChek
« Reply #4 on: May 23, 2012, 09:17:49 am »
Which games in particular do you see having the biggest improvements in the latest versions? I haven't kept up with the updates.
JayB
« Reply #5 on: May 23, 2012, 12:19:15 pm »
Hi, I'm just gathering the bits I need to start the process. Do you know if with 113 it will remove the loading/artwork thing too?
Thanks again
