Main > Everything Else
PSA: Portal 2 on sale for $6.79
shmokes:
I'm going to sound like I work for Valve here (hint: I wish), but FWIW Steam also gives you the option of purchasing games to be gifted to others. If you know anyone who hasn't played Portal, this is a very inexpensive way to remedy that situation.
Well Fed Games:
--- Quote from: pinballjim on May 10, 2012, 09:53:47 am ---Loved the first one, got bored halfway through the second one. The jokes had worn pretty thin by then and there was really only so much you could do with the puzzle format. Admit it, you blew through most of the levels in the second one without hardly trying.
I would say the puzzles in the 2nd one definitely get better and better by the end, as did the plot/humor. I assume since you got bored you didn't play the whole thing? If so, you also missed one of the best endings in all of gaming. I would say give it another try and see if you still feel the same way.
ahofle:
--- Quote from: shmokes on May 10, 2012, 12:34:00 pm ---I'm going to sound like I work for Valve here (hint: I wish), but FWIW Steam also gives you the option of purchasing games to be gifted to others. If you know anyone who hasn't played Portal, this is a very inexpensive way to remedy that situation.
That's exactly what I did. Both Portal 1 and 2 together are $8.49 if you know someone who hasn't played either.
fallacy:
fallacy:
Who was that in the door on 5:53?
