May 07, 2024, 09:47:35 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Forum notices to gmail.com addresses are working. Microsoft addresses are still not.
The NEW Build Your Own Arcade Controls
Main
Main Forum
Bartop Arcade Mark 2
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Bartop Arcade Mark 2 (Read 5186 times)
CoryBee
Trade Count:
+2
Full Member
Offline
Last login:October 21, 2023, 07:12:25 pm
Bopity Boopy
on:
May 03, 2012, 05:12:38 pm »
Here is model 2 of my bartop arcades built from yet another IBM thinkpad laptop.
As I said in the post Mark 1, I suck at painting. I tried to paint it black and I did not like the look.
Here is some shots of the Usb Joypad and underside of buttons. Excuse the dust as I was still in my workshop area.
The power button is a Mo-Fo on these old IBM laptops, had to cut into the traces of the keyboard.
Here is a shot of the laptop mounted to the screen support.
Here is the fan.
And here is the wiring to the Ac Adapter and powerbutton for laptop.
I then added a power switch to turn off the power to everything, added a nice touch to it and saves power.
The powerswitch also has an LED in it.
Those green things are terminal strips I use to easily disconnect wires for servicing. A touch I think I will use frequently.
Here is but a simple set-up for lighting my marquee.
All power for the fan and light bulbs come directly from the ac charger. This is an issue because the bulbs are 12v and the ac outputs 16+ unregulated volts
This is fixed by ading a voltage regulator I got from Radioshack for 4 bucks. It effectively reduces the voltage to 11.5 volts.
Here are some back shots before the Powerswitch was in place. You can tell I went with contact paper =)
Here are my mounted speakers I wired directly to the output of the laptop.
Thought it needed a volume knob so to radio shack I went. Mounted and soldered in.
Printed out a marquee real quick of one of my favorite games.
And here are some final shots of the baby arcade.
And finally here is Punch Out!!
My next bartop I am building is going to be a 2 - player running on a slightly faster laptop. It will have N64 controller port, TopGun 3 wireless gun and other features I cannot remember right now.
Thanks for looking. Will have a video uploaded shortly.
Last Edit: May 03, 2012, 05:34:51 pm by CoryDee
Logged
Full Size Archive
Mini\Micro\Cabaret Archive
Bartop Archive
Cocktail
S.A.M. - Stand Alone MAME
ChrisK
Trade Count:
0
Full Member
Offline
Last login:April 23, 2017, 12:06:50 pm
Re: Bartop Arcade Mark 2
Reply #1 on:
May 04, 2012, 02:47:35 pm »
I've got an old Dell laptop I've been eyeing for just such a project. A couple questions:
1) How did you wire the volume dial? On the line out from the motherboard?
2) How did you handle the ribbon cables for the screen? It looks like you folded the laptop over backwards after de-casing it? Is it as simple as that? It seems like it would be tough to mount that big pile of laptop parts securely that way.
Logged
CoryBee
Trade Count:
+2
Full Member
Offline
Bopity Boopy
Reply #2 on:
May 05, 2012, 06:04:47 am »
It is a simple rheostat from radio shack that handles the audio dial.
http://www.radioshack.com/product/index.jsp?productId=2062299.
So I cut the line from the laptop speaker and fed it to the volume knob, then to some speakers I pulled from some cheap mp3 amplifier I got for 7 dollars that broke.
Yes after removing the casing I just mounted the laptop screen to a little mount I made using 1x1 wood (or smaller). Then attached the mother board with a ton of hot glue. It holds to wood like a champ. Made sure the laptop was aligned with the screen and connected the screen back. It is as if you didn't have hinges and made the laptop into a tablet, just without the shell. if that makes sense. I am building 2 more as we speak and am doing a more detailed log.
Logged
Full Size Archive
Bartop Archive
Cocktail
ChrisK
Trade Count:
0
Full Member
Offline
Reply #3 on:
May 05, 2012, 09:20:55 am »
So the motherboard is completely de-cased, then? And glued onto the wood casing, not the screen, right? That seems like a pretty quick and easy way to mount it. I'd definitely be interested in the pictures of your next build before the cab itself goes together, if you think of it. I'm a newbie at building this stuff, and I'm thinking my first project will be a mini single-player cab like this using my wife's old Dell laptop.
Thanks for the info!
Logged
CoryBee
Trade Count:
+2
Full Member
Offline
Bopity Boopy
Reply #4 on:
May 05, 2012, 02:54:00 pm »
Yea that was my thoughts jumping into building an arcade cab. Spend next to nothing, and learn.
Here is my first build, I think it went pretty well, no acrylic control panel though.
http://forum.arcadecontrols.com/index.php?topic=119996.0
I didn't spend more than 60 dollars on it.
Logged
Full Size Archive
Bartop Archive
Cocktail
ark_ader
Trade Count:
0
Full Member
Offline
Last login:March 02, 2019, 07:35:34 pm
I glow in the dark.
Reply #5 on:
May 05, 2012, 05:36:28 pm »
I tend to leave the monitor in the casing after drilling some holes to mount on the MDF. Those inverters are really easy to fry.
I always find the side power switches hard to solder, but Thinkpads are much easier to use than say Dell or HP.
I'm looking at 2x TP 240s and 2 unfinished projects......
Nice little build.
Logged
CoryBee
Trade Count:
+2
Full Member
Offline
Bopity Boopy
Reply #6 on:
May 05, 2012, 06:52:25 pm »
Thanks pinball jim. I didn't even think to try and run a custom sized piece of paper. Can you elaborate or pictures of what you men? I think I get the jist of it though.
Also, i tape up the inverter =). I might keep the back on next time if it doesn't get in my way. Might be a little loose with it on not sure.
Thanks for commenting. Am working on a new model with 2 player, n64 ports and a light gun (Mark 3 Bartop). Still waiting for parts on that one. So while I wait I am making 3 more of this design.
Logged
Full Size Archive
Bartop Archive
Cocktail
CoryBee
Trade Count:
+2
Full Member
Offline
Bopity Boopy
Reply #7 on:
May 06, 2012, 12:50:46 pm »
Ok, I just finished cutting and assembling some more mark 2 cabinet shells. I was asked so I made a build log, take a look at the process.
http://forum.arcadecontrols.com/index.php?topic=120067.msg1272785#msg1272785
Logged
Full Size Archive
Bartop Archive
Cocktail
CoryBee
Trade Count:
+2
Full Member
Offline
Bopity Boopy
Reply #8 on:
May 08, 2012, 08:39:24 pm »
I am uploading a video shortly, well once my camera recharges.
Logged
Full Size Archive
Bartop Archive
Cocktail
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
