Main > Main Forum
Marquee retainer options
alfonzotan:
--- Quote from: not_so_handy on May 03, 2012, 03:16:37 pm ---eds1275 that might be exactly what I am looking for. My build isnt based on 90 degree angles either. I may have to get my friend to pick this up for me this weekend when hes in Toronto. Cant believe i didn't see that either. I got my coin door from them and i swear i scoured their site :cheers:
The plastic corner protectors are fine if the angle isn't 90 degrees (mine isn't). They flex.
not_so_handy:
i think I may try the ones from playdium first as I am looking for something that's more rounded as it goes more with the style of my cabinet. Its very curvy :)
mcseforsale:
I used the clear one and painted it black from the inside... a la R/C car bodies. Painting from the inside makes the paint scratchproof (unless you scratch it from the inside) and the finish is gloss.
AJ
Dawgz Rule:
I went with the marquee retainer and love the look on my cab. I routed out the top an bottom of the attachment points on the cab to ensure a smooth fit. I secured them with black automotive screws.
yotsuya:
--- Quote from: mcseforsale on May 04, 2012, 09:50:57 am ---I used the clear one and painted it black from the inside... a la R/C car bodies. Painting from the inside makes the paint scratchproof (unless you scratch it from the inside) and the finish is gloss.
AJ
Great tip!
