Main > Main Forum
Minipac issues
Pages: << < (4/4)
Los Abrazos Rotos:
--- Quote from: MTPPC on May 02, 2012, 10:44:34 am ---elaborate please.
We ruled out everything it could have been - turned out the card wasnt faulty, it was a programming issue. The damage I did to it doesn't appear to affect its performance in any way.
Los Abrazos Rotos:
Thanks for the help in this thread btw  :)
AndyWarne:
--- Quote from: elkameleon on May 01, 2012, 10:01:33 am ---I have the minipac, and let me tell you, its not as easy to set up as it seems. :soapbox: First, you have to wire it a certain way, I found that out the hard way after I couldnt just assign whatever button I wanted to whatever control I had hooked up. OH NO it don't work that way! Wire it correctly, then when you set up your buttons, you need to make sure you hit the program button, I hit mine 5 times in a row, it doesn't always take for whatever reason. IMHO, I think the step software could be a little easier to use.
You can assign any pin to any control. But on the other hand if you wire it according to the diagram you dont then have to do any setup at all, it should just work.
We try to inform people that on the Minipac (and I-PAC) its not necessary to program or set up the board. Also, if it does not work immediately, trying to program it is not the way forward. Any wiring issues etc need to be corrected as a first step.
We recently stopped sending out the WinIPAC program with boards and now send a link to download it, and on the link there is a warning not to program the board unless you have everything working first, and then only program if you have a need to change the default configuration.
elkameleon:
--- Quote from: AndyWarne on May 03, 2012, 03:18:10 pm ---
I've since figured that out, but then a year later, I needed to change a button configuration, and I had to relearn how the software worked again and what it was expecting of me. It's definately not for the faint of heart, thats all i'm saying, but when it work, it work great.
MTPPC:
On my main mame cabinet, I installed a button under the control panel for the shift. I reprogrammed my J-Pac for this hidden shift button because I have kids on the cabinet and I hate having to go over and help them get it going again when they are mashing all the buttons in a random fashion. Besides for SNK fighting games, P1 Start is taunt and I don't want unexpected things happening while I'm taunting.
Pages: << < (4/4)
Go to full version
