Main > Project Announcements
My first project: PiCade, low cost arcade emulator.
johncl:
--- Quote from: javeryh on September 20, 2012, 12:40:11 pm ---Where are you seeing 7" monitors that are 4:3 with a VGA port? I'd be very interested if the price was right.
Well, as I said I can find several 7" screens with RCA (video in) input, not VGA input (which is no good for RPi). Neither can I really find 15" LCDs with DVI or HDMI input to save the day. Most cheap 4:3 ones you can find have a VGA input. Which again baffles me a bit since obviously the cheap RPi can be used for hooking up old monitors which all have VGA ports. Most monitors I can find today with DVI (which could have worked with a HDMI->DVI adapter) are 16:9 which really isnt the best way to go for a Donkey Kong machine. :) - The more expensive HDMI to VGA adapters will naturally work (I guess there are some cheap ones from China you can buy on ebay) so I might even go that route if I want to use the RPi for my project.
As for 4:3 7" screens you can find some used ones from e.g. Liliput around, but I feel almost all these have exceptionally low resolution for an arcade. I'd rather have a 1024x768 LCD for this to emulate some raster lines as well. ::)
Jigenjuke:
--- Quote from: johncl on September 19, 2012, 07:27:28 am ---
--- Quote from: Jigenjuke on September 19, 2012, 07:10:31 am ---Hey there johncl,
I am using an older version of a VIA board the M10000. This runs great with MAME 32 1.32 under windows XP. I am using 256megs of ram and onboard video.
Jigenjuke
Hi, and thanks that good news to hear. I seem to recall reading many using these old Via boards for mame so I was really at a loss at how to achieve this. But you know, I'd rather avoid XP alltogether as I really wanted to have a free OS on this thing, and preferably something that boots much faster directly into mame. It sounded to me that AdvanceMame would be the thing, but the only bootable distro they made of that was AdvanceCD which has very limited hardware support it seems. The pure AdvanceMame DOS builds seems to support the Via chipset but alas I have had no luck running that from FreeDos at least. Perhaps I need MSDOS for it to run? Perhaps some memory issues that need to be adressed (I recall that as being a problem in MSDOS when I tinkered a lot with that 20 years ago). Or perhaps it simply some configuration I need to do to enable the Via chipset drivers to run? Also I have found OpenChrome which should be Via drivers for linux, perhaps I need to install or compile and configure these in some way (both of these are things I have no knowledge of as I am very green in the linux world).
Ah I also read that maybe I need to use an old mame build as the latter ones are too CPU intensive? Perhaps I can get an older one running on puppy arcade? Any idea how I would go about getting that? I will only run the classics like Donkey Kong and Pac Man on this arcade project.
Also if anyone has a bootable image of a linux/dos distro for Via chipset with a working mame I would be eternally grateful! :)
BTW Jigenjuke, fantastic mini arcade projects you are working on, amazing that you are making so many of them at the same time. My current project which I will make a thread about here soon is a classic Donkey Kong Bartop similar to this one. I am quite sure I tried this exact bartop on R3Play 2010 in Blackpool and perhaps even had a short chat with the creator. I got some free 11mm MDF which could work very well for this project although I will have problems fitting white t-molding to it, but more about that when I start my own thread. :)
BTW2: Sorry for "offtopic'ing" this thread, please continue with the PiCade work/chat! I just got my RPi in the mail yesterday! If that works fine for DonkeyKong I might even try to find a 4:3 LCD with a video-in port since the RPi has that output (imo the RPi sorely lacking a VGA port).
Hey there again Johncl,
As far as a 7 inch VGA monitor you could try a Lilliput 7 Inches VGA Tft LCD Monitor. I have used these before and they work very well especially with the VIA chrome chipsets, but I don't think that you will find one to keep you in your price range. I made three 3/4 size "bartops" DOnkey Kong, Mario Brothers and Donkey Kong Jr. a few years back. I started out using Fujitsu PCs but then soon switched again used the EPIA Via M10000 boards. In these machines I was lucky to find some cheap 15-17inch 4:3 monitors on the Japanese Yahoo auction site. Many of the 17 inch 4:3 displays here in Japan have the dvi input, but again it would be cost prohibitive to send one to you. Look around I believe that the Iyama monitors have what you are looking for in maybe a 17 inch size. These would fit beautifully in a DK replica "bartop". If there is anything I can do to help let me know.
Many folks here have suggested an adapter. That's probably the best way for you to go. The little 8.4 inch monitors I have in the Mini Pac/Ms. Pac replicas are point of sale touch screen monitors for the local shipping company here in Japan called Kuronekko. These are great but I haven't seen anymore recently.
You can check out the DK, DK Jr. and Mario thread here... And thanks for the kind words. Good luck!
http://forum.arcadecontrols.com/index.php/topic,85596.msg897800.html#msg897800
Jigenjuke
johncl:
Hi and thanks for your reply. I guess I have been a bit confusing in my posts about what i am actually seeking. :)
I have a very nice HP 15" 4:3 LCD with a VGA port now that I planned to use in my 1/2 size Donkey Kong bartop (fits perfectly in the design with 30 cm width front). My original plan was to use a Via Epia 13000 board for this but so far I have had no luck getting 100% framerate on even simple games like Donkey Kong. Then at the same time I see some people running Mame games on the RPi (which I recently also got) and I wouldnt mind using that instead since its so small and possibly an excellent choice for projects like this. Now the problem is that the RPi dont have VGA output so I started hunting for 15" LCDs with either a RCA (video in) or HDMI, but the only ones I can find with HDMI at least are bigger than 15" and 16:9 format. Furthermore, the only ones I can find with RCA input are the car screens which normally are no bigger than 10" (mostly 7" or lower) - and these all have very low resolution.
And as you say you can find 17" 4:3 LCDs with DVI port, getting smaller ones like 15" with DVI is harder it seems since DVI was introduced as most screens produced were 17" or higher. The only 15" I have found with both DVI and even HDMI are all very expensive storefront touch screen things at $300+.
Basically you can find on ebay and many places today very nice used 15" 4:3 format LCDs for $25 (I got mine for about that) but they all have a VGA port. If my option is to buy a new screen for $150+ I might as well just get a mini-itx Atom based board with a VGA output and use my 15" for the project. Hope that clarifies. :)
Although my hopes are still to get Mame running fine on the Via 13000 which really should be faster than the 10000 or even 5000 which I know some people run mame on. To further complicate matters I dont want to run WinXP but Linux since I want a faster boot directly into the game if possible. :) I am just starting out on Linux really so perhaps I can build some older mame version that works fine for games like Donkey Kong (see my other thread about this question).
Again sorry for the offtopic chat, I'd be interested in following the OPs RPi project as it can be a very good discussion for using the RPi in arcade projects, both mini ones or bartops. If anyone find good suitable 15" 4:3 screens for the RPi then I am sure more people than me would love to know where to find them! :D
EDIT: Small update, I have been able to use Rufus 1.1.7f to make a bootable USB Stick with FreeDos AND install Dos Mame 0.90b which boots fine on a Thinkpad at work and Mame worked fine with donkey kong after installing a memory manager file that was missing. I found most info here which is a very nice site about Mame in DOS. The whole thing boots exceptionally fast from USB stick and Donkey Kong loaded immediately. If I can get this working on my Via Epia CN13000 at home I will be very very happy. I see that it should support AC97 sound chip as well as it can emulate a soundblaster. Cant wait to try this at home as it will be a much cleaner solution than booting into WinXP or a Linux desktop to run Mame. It feels like a DonkeyKong on a stick ready to be played anywhere :)!
EDIT2: Jigenjuke, thats some amazing bartops you have made in that other thread. How could I have missed that. You also have a red DonkeyKong bartop just like the one I am making. I also notice you use 12mm MDF which is about the same size as i am using (mine might possibly be 11mm). I'd be very interested in how easy it was to cut the groove in that for the t-molding. I am a bit afraid that it might split up since the boards are a bit thin at 11-12mm. If it works fine I will surely get some of that 1/2" t-molding which I assume you have cut nicely with a knife after mounting it to make it flush with the sides?
Navigation
[0] Message Index
[*] Previous page
Go to full version
