Author Topic: Monitor Rotation using Timing Belt  (Read 1733 times)
kahlid74
  • Gaming for a better future!
    • GamersAnon
« on: April 25, 2012, 10:50:16 am »
I not super knowledgeable about timing belts so I was hoping to get some help finding two timing belt pulleys I can use.  I need an 8MM (5/16 in) bore Timing belt pulley for my stepper motor and a 3/4 in. Timing belt pulley for my shaft.  I've found some with both 5/16 and 3/4 on McMaster-Carr but they seem to be for different size timing belts with different pitch.
Anyone know where I can find some these with the same pitch and sized timing belt?
TopJimmyCooks
Re: Monitor Rotation using Timing Belt
« Reply #1 on: April 25, 2012, 11:17:37 am »
mcmaster and grainger sometimes list the supplier of the items they sell.  look at the manufacturer and track them down directly.  they will know what sizes are available, etc.  I did this with pogo pins a while back, had to go right to the maker but they had what i needed.
it could well be easier to find a belt you can live with and then find sheaves (pullies) to match, more variety of those around.
kahlid74
    • GamersAnon
« Reply #2 on: April 25, 2012, 12:23:39 pm »
Following your advice I pushed to manufactuer's and found these guys have 5/16 and 3/4 in bore L series pulleys with 3/8" pitch.  So it should be good to go ordering these.
http://torquetrans.com/pulleys/timing-pulleys/l.htm
This is exciting.  I've been on stand still looking for pulleys.  My arduino code is almost ready too!  Soon, there shall be a rotating 42" TV in the near future.
« Last Edit: April 25, 2012, 12:37:02 pm by kahlid74 »
TopJimmyCooks
« Reply #3 on: April 25, 2012, 01:37:57 pm »
glad to be of service.
kahlid74
    • GamersAnon
« Reply #4 on: April 25, 2012, 01:57:01 pm »
Just another update in-case anyone else ever needs them, I called them and got directed to Quality Transmission Components and they have boat loads available.  So yeah, awesome sauce - http://www.econobelt.com/e-store/Pulleys.htm
So once pulleys arrive try out Arduino code and then I'll start a project thread about building the cab lol.  It's going to be a monstrosity.
  • Last login:December 13, 2023, 12:03:14 am
« Reply #5 on: April 25, 2012, 01:59:19 pm »
Cant wait to see this rotating monitor project finished! Dont forget to post a link to your project over at Automated projects forum.
kahlid74
    • GamersAnon
« Reply #6 on: April 25, 2012, 02:26:00 pm »
My biggest challange is time.  With Mechwarrior Online coming out Q3/4 of this year I need to finish my Battletech pod, which means this machine is most like going to be built skeleton wise and then site for several months until BTech pod is done.  I do however plan to use stepper motors in the BTech pod to when you close the pod door move a rail system with three monitors towards the pilot and bloom like a floor inside the cab.  I'm super excited to get to that one!
