| Main > Project Announcements |
| Vigolix, a super easy mini cab on 1 sheet of 2X4 plywood |
| << < (26/28) > >> |
| Vigo:
--- Quote from: Loper on February 18, 2015, 07:17:44 pm ---(Really not sure if this is the place to post for sure but it seemed appropriate to me at the time of this writing.)I am new to the forum, and had first heard about it after seeing this project and wanted to build one of my own. After about a year of planning and scraping one idea after another I decided that this design was in fact the way to go. My limitations are mostly living space, as I only have a small section of home office to put a cab and the Vigolix design fits the bill, and corner. But being the dreamer I am, I wanted to see how far I can push the design while staying true to the original plans. Just how much cool stuff can I fit in this cab? Well I loaded up SketchUp and decided to find out. At this point I would say my design is 80-90% done and I cannot wait to get started. It is going to take some time to save up for it and I will more than likely be working on it for over a year and dropping around $1,000 into it, but I would like to introduce the Noir-Cade (I'm still open for a better name.) It is going to run on an AMD A10-7850K APU and eventually the GTX 750 ti that is currently in my main PC when I upgrade the GPU on that. It's going to be cooled by a Corsair H100i and I would like to fit a Logitech LS21 in if possible, gotta have a little bass. The joystick, trackball and 14 buttons are going to be RGB LED connected to a Howler controller. It's a bit ambitious, but I hope to get it done they way I plan. Once I have enough parts to get the build truly started I will start a thread for the build with updates on progress. --- End quote --- Hey Loper! Thanks for the post. Sorry for the lack of reply, but I couldn't figure out the images right away. I am reposting them below, as long as you don't mind. Pretty slick! Is that gonna be plexi glass in the front? 8) My only question of concern is on the control panel. Simply that you have an 8 button layout but all the buttons are straight. Usually the left most column is lowered down so it is easier for the thumb to use that button. I also am guessing there will be a marquee area on top? Other than that, I think this is gonna look really great. :cheers: |
| Loper:
Sorry my reply is so late. Life happened. Yes the front will be plexi, but it was not yet added to the sketchup model in these images, and as far as the straight button layout, that is a concept i want to try for a couple of reasons, I will rarely use all 8 at the same time, and when I do it will likely be things like final fantasy 7 and 8, so when it comes to things like neo geo, i want to try the top right 3 with one on the bottom row for the 4th. and i also want to see how the top row plus the one in the bottom row that is centered under those works with asteroids. I would post updated images but i am not sure how to get the images to post. |
| danny_galaga:
Late to this thread, but nice work Vigo on the minimalist approach. I like minimalist, which is why I've nearly finished building cab with about 6 different sheets of MDF… Hey, I'm a whiskey priest. |
| DeLuSioNal29:
Pics or it didn't happen! |
| Vigo:
--- Quote from: danny_galaga on April 04, 2015, 05:16:32 am --- Late to this thread, but nice work Vigo on the minimalist approach. I like minimalist, which is why I've nearly finished building cab with about 6 different sheets of MDF… Hey, I'm a whiskey priest. --- End quote --- Thanks, Danny! :cheers: :lol |
| Navigation |
| Message Index |
| Next page |
| Previous page |
