Main > Everything Else
I require aid from the solder king!
Mikezilla:
Thanks for all the input guys. I had no idea that soldering batteries was a bad idea. Ill try hotglue first, then try those battery clips you guys mentioned. I went to Radioshack, and you guys called it, the guy there didnt know anything, he didnt even know where the LEDs were in the store. ::)
--- Quote from: pinballjim on April 11, 2012, 05:47:21 pm ---Obviously better to use holders, but c'mon. Sometimes you gotta do what you gotta do.
Lead fumes are harmless, Mike, and you don't need to have children. I suggest you inhale deeply and frequently.
Thanks for the suggestion. ;)
Nephasth:
--- Quote from: HaRuMaN on April 12, 2012, 09:56:47 am ---
--- Quote from: Nephasth on April 11, 2012, 07:39:55 pm ---Here's a ? for the solder king... What's the average longevity of a tip?
I go through one about every 6 months... (15 Watt Radio Shack tip). I'm using it a lot, though.
Do you resharpen/reshape the tip in that time frame? I'm finding that my tip will gouge/groove out during long soldering sessions (making the tip kind of hook like). Don't know if it's improper technique or normal.
Mysterioii:
I've never had that happen, myself.
HaRuMaN:
--- Quote from: Nephasth on April 12, 2012, 12:18:19 pm ---
Nope, never had that happen.
mountain:
--- Quote from: HaRuMaN on April 12, 2012, 09:59:01 am ---
--- Quote from: yotsuya on April 11, 2012, 06:31:30 pm ---Any tips for tinning the tips or wires? I've done some limited soldering but want to make sure i'm doing it correctly.
As far as soldering technique... apply a little flux to the spot you want the wire to go, and then apply a little dab of solder to that spot. Take your stripped wire, apply solder to the end, and then hold the wire to the spot, apply heat, and done.
When using rosin core solder there is no need for flux. That's what the rosin is for. I have done my share of "wire welding" over the last 25 years being and Avionics Tech, and now working for an electronics manufacturer. The most useful tip I tell people is pay attention to heat transfer. Taking a "dry' tip to a dry subject and then trying to get solder to flow is wrong. You will heat up the wire (or whatever you are soldering) too fast. Pre-tinning the tip is essential. Once the flow begins between two surfaces, you're done. The tip should be pulled away within a couple of seconds.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
