Main > Everything Else
I require aid from the solder king!
HaRuMaN:
--- Quote from: Nephasth on April 11, 2012, 05:24:16 pm ---
--- Quote from: Mikezilla on April 11, 2012, 05:17:52 pm ---Any suggestions on how to solder the wires to the batteries?
Don't.
Yeah, heat + batteries = bad. Get battery holders and solder to those.
Nephasth:
Hot glue?
Mysterioii:
After years of using a cheapo radio shack wood burner soldering iron I broke down and got myself a Weller digitally temperature controlled one, and I'm very happy with it. It wasn't cheap but to me it was worth every penny (plus I wrote it off on my taxes as a business expense so it was essentially 30% off...) ;D But really, it's whatever you're comfortable with. Definitely try a cheap one first and see if you're happy with it.
And yeah like they said... don't solder to the batteries. ;)
knave:
--- Quote from: Mikezilla on April 11, 2012, 05:17:52 pm ---I got my iron from HF!!! :lol It was only 4 bucks. So wait a minute, isnt lead toxic? Is it safe to breathe in the fumes when you burn it? The one I have, like DR mentioned, doesnt stick to anything. Im just soldering LED wires together. Any suggestions on how to solder the wires to the batteries?
All HF jokes aside...you can get the Radio shack iron for only a few bucks more...do it. but you are welcome to find out for yourself.
FYI I think the iron by itself is $7.99 at RS, I bought a kit for $15.
For batteries I order them with solder tabs on them. I reccomend you do the same.
Also...if your iron is new make sure you tin the tip as well...
Good luck.
yotsuya:
Any tips for tinning the tips or wires? I've done some limited soldering but want to make sure i'm doing it correctly.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
