Author Topic: Why oh Why i-Pac 4?  (Read 1183 times)
mcseforsale
  • Last login:April 09, 2024, 03:07:41 pm
  • Creepy Mario Dude
Why oh Why i-Pac 4?
« on: April 08, 2012, 09:37:38 am »
I've had the iPac 4 for a few years and used it to build my 48" monster that never found a home in a cab....now, I'm trying to build a Knievel CP and the damn thing is waaaayy too big.  I want to do an LEDWiz, too, but real-estate is, well,...at a premium.
From here:
to here:
Damn.  What to do?
AJ
yaksplat
    • Random Projects
Re: Why oh Why i-Pac 4?
« Reply #1 on: April 08, 2012, 09:53:46 am »
Looks like you have a ton of room in that box.  What's the issue?
http://yaksplat.wordpress.com
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2 on: April 08, 2012, 10:06:23 am »
+1 on that.
You don't have to mount the ipac on the underside of the control panel you could mount it anywhere.
DaveMMR
    • TeeVee Games
« Reply #3 on: April 08, 2012, 10:27:56 am »
I ended up slapping both my LEDWiz units and another encoder on the inside of the cabinet with the wires feeding through to the panel. I was going to add some sort of quick disconnect system (like an IDE cable or something) but I got lazy.
But as the others have said, you look to have plenty of room to work with.
mcseforsale
  • Creepy Mario Dude
« Reply #4 on: April 08, 2012, 11:08:31 am »
The top pic is my 48" x 19" CP that I just disposed of.  The bottom one is the 33 x 15 one that I just built.  Here's a better pic:
That iPac is fugging HUGE!  :dizzy:
I'll have an Opti-pac, and iPac-4 and an LEDWiz (or pac-led) once I'm done.
I'm also going to be using solid-core wires, so...
AJ
TopJimmyCooks
« Reply #5 on: April 08, 2012, 11:59:40 am »
you're fine on room.  mount the interfaces on the bottom of the box like I did if you're worried, although given the size of your cp top I would undermount them. nothing needs much clearance, things can be close together.
« Reply #6 on: April 08, 2012, 12:03:01 pm »
I went with inside the cabinet for my interface boards. http://forum.arcadecontrols.com/index.php?topic=108719.msg1226171#msg1226171
