Main > Project Announcements
Arcade Invaders Cabinet (was Street Fighter)
brad808:
--- Quote from: Termin8tor on April 08, 2012, 07:02:53 am ---Decided on a Street Fighter theme after all. I couldn't find a decent moves strip so I made one up, what do you think?
It's cool looking but not really accurate to any of the sf2 variants. If your thinking plain vanilla sf2 world warrior then you might want to remove the moves that don't apply to that game such as all the "super" moves and a lot of the moves that got introduced in later sf2 games. If you want it to be ssf2 turbo type theme then maybe try and add the other characters in somewhere. Possible around the bezel? Just my thoughts. Build is looking real good though.
Termin8tor:
Thanks for the reply I'am going for the super street fighter 2 turbo look with the other 8 characters on the bottom of the bezel.
Termin8tor:
First undercoat applied. First I sealed the edges of the MDF with a water+wood glue mix which works pretty well and then added the first coat, let dry overnight and sanded it with a 150grit sand paper. I will probably go with another 2 undercoats using a finer sandpaper each time and finish off with a top coat of a dark blue gloss.
Some Pics:
Termin8tor:
Lexan cut for control panel, marquee and bezel.
Seith:
I really like this design, although I am personally going for a variant of the Jakobud cab design... really digging the candy-esque receeded marquee. Any reason you decided to go this route over a more traditional design?
Also, where are your speakers going?
