Main > Everything Else
Using a car Engine Start Button
cyberphox:
Thanks for all the replies, gonna go check out this links now!
bkenobi:
FWIW, the led in the power button will only be on when the computer is on. If you wanted the LED to remain lit whether the computer was on or not, that would require a DC source for the LED separate from the computer PSU.
wp34:
--- Quote from: yaksplat on March 26, 2012, 08:56:48 am ---If you follow these, it should give you an idea on how to wire it all up. 12VDC switch with an led in it switching a 120VAC source.
http://yaksplat.wordpress.com/2011/10/27/wiring-up-the-main-power-switch/
http://yaksplat.wordpress.com/2011/11/21/main-power-switch-wiring-part-2/
Yaksplat - I appreciate your tutorials. The "Wiring up the main power switch" one is actually fun to read which is no mean feat.
The best part is when I read them I hear Ron Swanson. :cheers:
Navigation
[0] Message Index
[*] Previous page
Go to full version
