Author Topic: NEW VERSION of Vertical Games on Horizontal LCD  (Read 2854 times)
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
« on: March 24, 2012, 09:25:16 pm »
These are instructions for making vertical games look bigger and better on horizontal lcd monitors.
This new version allows fine tuning for every vertical game:
- You can keep the game original flat (with or without pincushion).
- You can tilt "the monitor" back with adjustable angle and pincushion.
- You can still play horizontal games, but requires scaling them to 66%.
- Setting are saved in hlsl folder. (No more manual editing).
Note! This is a mod of the post.fx file and is not a part of mame development.
Why I made this:
- I am using a 24" FullHD (1920 x 1080 - 120Hz) monitor (any horizontal monitor should do).
- Vertical games look small, flat and boring on horizontal monitors.
- I like the old curved monitor look.
- Many of the best arcade games are vertical.
- Stretching the game beyond 3:4 is NOT an option.
Step by step:
1. Extract the attached lcd.rar and copy post.fx to the HLSL folder.
2. Enable HLSL in mame.ini and do the following changes:
- hlsl_ini_read 1 // reads hlsl game settings in the hlsl folder
- hlsl_ini_write 1 // writes hlsl game settings in the hlsl folder
- curvature 0.5 // IMPORTANT starting value used for the mod
- pincushion 0.1 // minimum starting value for mod to work
(Other HLSL settings like scanlines, defocus etc. are optional.)
3. Start any vertical game in fullscreen (or alt - enter from windowed.)
4. Adjust the following settings in TAB - Slider Controls for each game:
Screen Curvature (experiment with this - 0.5 is center)
Image Pincushion (experiment with this 0.1 - 1.0)
Screen Horiz Position (vertical position)
Screen Horiz Stretch (vertical size)
Screen Vert Stretch (same value or up to 10% more then "Screen Horiz Stretch")
Tip! Temporarily adjust "Screen Brightness" to 1.2 makes it easier to adjust.
Example "Slider Control" settings for BombJack:
Screen Curvature 0.7
Image Pincushion 0.5
Screen Horiz Position -0.130
Screen Horiz Stretch 1.1
Screen Vert Stretch 1.2
Only five lines are changed and one added in post.fx. Just open post.fx in notepad and search for "ORIGINAL" to see for your self.
ENJOY !  :)
wildclay
  • Last login:May 20, 2013, 11:07:21 pm
Re: NEW VERSION of Vertical Games on Horizontal LCD
« Reply #1 on: March 24, 2012, 09:46:21 pm »
Nice. Thanks for sharing!  I was actually just playing around with vertical monitor settings on Donkey Kong earlier today. I have to give this a try.
Hunk_4TH
  • Last login:March 05, 2024, 06:55:10 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #2 on: May 20, 2012, 11:42:10 pm »
A little late on this. But thanks for continuing to work on this! Though I'm not sure I follow you here
RetroBorg
  • Last login:July 06, 2022, 09:22:13 am
« Reply #3 on: May 21, 2012, 02:45:15 am »
Looks interesting.
Hunk_4TH
« Reply #4 on: June 03, 2012, 06:21:06 pm »
I tried the settings but it doesn't seem to work :( Can you post your settings file?
Hunk_4TH
« Reply #5 on: June 18, 2012, 05:10:43 pm »
I guess no one is using this anymore? :(
