Author Topic: MAME Mouse Problems  (Read 1453 times)
StratMan9000
  • Last login:July 07, 2016, 02:20:48 pm
    • MAME Cabinet build progress!
MAME Mouse Problems
« on: March 24, 2012, 06:57:51 pm »
Hi all, I wasn't sure whether to post this in the General forum or Software, but anyway...
I finally have my cabinet almost up and running, there are just a few problems in my way now.
First of all, I am using a Happ trackball and a Hagstrom KE72-T, as well as the SlikStik Tornado spinner. The problem I am running into is that on the trackball, the x-axis is reversed; so whenever I move it to the left it goes right, and vice-verse. The other problem is that I have the spinner in vertical mode, and when I turn the spinner clockwise it goes up, and when I turn it counter-clockwise, it goes down. Is there something in Windows that I can fix this with?
When arguing with idiots, there are so many things that can and will go wrong, that it is best to avoid it at all costs.
MTPPC
Re: MAME Mouse Problems
« Reply #1 on: March 24, 2012, 09:05:31 pm »
When you have a game up on mame, hit tab and set the the Input (General).
http://pinballmd.com/
wildclay
  • Last login:May 20, 2013, 11:07:21 pm
« Reply #2 on: March 24, 2012, 09:54:17 pm »
As MTPPC mentioned, you can change it in MAME's General input setting (or via individual game settings if you wish). I had the same issue with Golden Tee when I first setup my trackball (also a Happ), now it works excellently!  I assume as a mouse in Windows it works correctly? Or does this same reverse issue occur with the pointer in Windows too? If it doesn't work correctly in Windows you may need a different mouse driver, else you should be able to play with the "pointing device/mouse" settings in the Control Panel.
topdawgg
  • Last login:April 01, 2012, 05:03:13 pm
« Reply #3 on: March 24, 2012, 10:06:38 pm »
I actually have a happ trackball and got two random questions (not trying to hijack the thread).
How did you get the trackball to work in mame?  It works as a regular mouse in windows, but nothing works in mame.
Also, the light that is under the trackball.... how do I connect that to make the ball light up?
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #4 on: March 25, 2012, 11:21:38 am »
In your mame.ini file, have you enabled mouse?  It should have a 1 next to Mouse instead of 0.
topdawgg
« Reply #5 on: March 27, 2012, 05:47:49 pm »
Nope... thanks will try it.
