Main > Main Forum
U360 will not load maps with Ledblinky
arzoo:
So that pretty much narrows the problem down to the ultrastik.dll - so lets test that without LEDBlinky.
Download this U360 Test app and put it into your LEDBlinky folder. Use it to set a few maps (4-way, 8-way, etc) and confirm if the sticks are actually mapped (using the same methods as before).
The app will generate a log file (UltraStikTest.log) if there are any detected errors.
If it doesn't work, try running the test app in Win 32 compatibility mode.
bbee383:
It runs, but doesn't generate log file
arzoo:
So it detects your u360's - does it set the maps correctly? Did you try the compatibility mode? The log file would only be generated if it detects a problem.
bbee383:
Yes it set the maps and didn't send a log.
I did this in reg and win 32
arzoo:
--- Quote from: bbee383 on March 23, 2012, 09:05:14 pm ---Yes it set the maps and didn't send a log.
Please email me your debug.zip file.
